Home » Eclipse Projects » GEF » UI conventions
UI conventions [message #197681] |
Wed, 05 October 2005 01:05  |
Originally posted by: alnospammajor.noboxspamspoon.com
this is not directly GEF related, but it's a logical place to post.
are there any UI guidelines/conventions for "long" tool interactions?
i'm thinking about interactions which might require multiple mouse
clicks to complete. and, for example, might popup something like an
auto-complete helper control in the middle of the interaction.
if there is no such guideline/convention doc for GEF, pointers to
equivalent docs for windows or mac or GTK, would be helpful.
regards,
al
Re: UI conventions [message #197762 is a reply to message #197681] |
Wed, 05 October 2005 11:26   |
> regards,
> al
I have avoided complex actions. if it requires a few steps, I try to
use a wizard. I never invoke a wizard when using a tool though. I used
too, but I reworked my logic so I didn't have to. try to keep things
simple for the user.
I am not familiar with any guidelines. I looked at programs that did
things similar to mine like Visio and TurboCAD, etc.
CL
Re: UI conventions [message #198027 is a reply to message #197937] |
Fri, 07 October 2005 00:13   |
for example, let me give a simplified description of the tool i'd like
right now.
this needs to perform multiple selection. if this were normal multiple
selection, i could use the <shift-click>/<ctrl-click> convention.
but in this case, the order of selection is important. and the feedback
figure is (lets say) a polyline that connects specific points on the
selections in the order selected. the autocomplete helper (if there is
one) would suggest (or restrict selection to) items that could be
selected next (by highlighting them in some fashion).
it does, of course, have to do the normal source/target feedback as well.
in this thread, i'm only secondarily concerned with the mechanics of
tool implementation. this seems do-able using AbstractTool as the base.
AFAICT none of the standard tools can be extended to cover this usage
(i'd love to be wrong!).
what i am concerned with is that i not invent new usage idioms, when
others have already created good ones that have become standardized in
conventions. or to inadvertently violate existing usage semantics. egs.
in this case, i'm not certain if i should use <ctrl-click> because its
semantics (unordered selection?) are apparently violated by the interaction.
and there are other interactions down the road that will (possibly) be
more complicated. so if someone has a handbook or reference to user
interactions, i'd like to check it out :-).
Randy Hudson wrote:
> I don't know of such interactions except for possibly creating a polygon or
> bendpoints as part of creating a connection. Could you be more specific? You
> might be able to get away with just changing the cursor, but that's not very
> cross-platform.
Re: UI conventions [message #198081 is a reply to message #198027] |
Fri, 07 October 2005 09:35   |
> right now.
> interaction.
<ctrl-click> is not unordered. use ctrl-click. You can use it in
concert with a special selection tool that numers the itens as you
select them or something. But ctrl-click is definitely ordered. For
example, look at align in most graphical programs.
CL
Re: UI conventions [message #198336 is a reply to message #198027] |
Mon, 10 October 2005 13:53   |
As someone else said, order is maintained in selection.
> one) would suggest (or restrict selection to) items that could be selected
> in this thread, i'm only secondarily concerned with the mechanics of tool
> implementation. this seems do-able using AbstractTool as the base. AFAICT
> none of the standard tools can be extended to cover this usage (i'd love
> to be wrong!).
The connection tool processes 2 separate mouse clicks. I don't see any
reason why a custom tool couldn't process more.
> conventions. or to inadvertently violate existing usage semantics. egs. in
> interaction.
If you display the polyline as the user selects, and the order already
maintained, this sounds like it would be intuitive.
The only request we have had like this I think I alluded to. It is to create
bendpoints during the initial creation of a connection. This is low priority
for us so we haven't spent any time on it.
Re: UI conventions [message #198568 is a reply to message #198518] |
Wed, 12 October 2005 10:18   |
> that may be true, but most 'improved' designes are poorly received. If
> you have the opportunity to make an improved UI go for it. But even as
> we speak, I play a game called eve-online, and they have shif-drag doing
> copy whereas normally ctrl-drag does copy. It took me 6 months to
> figure out how to do copy just because of that :(
as a concrete example, in this particular case, the similar programs
that i've looked at actually do multiple selection within a _tool
context_ by repeated clicks. _not_ by <ctrl-click>. so if i use
<ctrl-click> i'm 'improving' the design of existing programs and running
the risk, as you point out, of being received poorly by users. if i
don't, i'm violating a common user-interface guideline, and what you and
Randy both suggested as the correct way to go.
however, there are people that spend all their waking hours thinking
about user interaction. there's some good stuff out there written about
it. i'm hoping that i'll find something on "long" tool interactions
somewhere. since no one on the list appears to know of such, perhaps it
doesn't exist. in which case i will have to make my own decisions on
which way to go.
regards,
al
Re: UI conventions [message #198814 is a reply to message #198568] |
Wed, 12 October 2005 13:44  |
>> If you have the opportunity to make an improved UI go for it. But
>> even as we speak, I play a game called eve-online, and they have
>> shif-drag doing copy whereas normally ctrl-drag does copy. It took me
>> 6 months to figure out how to do copy just because of that :(
> which way to go.
> regards,
> al
Well there are tools that work on 1 item and there are tools that work
on an ordered set of items. And occasionally there are tools that work
on sets of items. For instance, CAD has lots of multi point things that
happen where the order of selection makes each selected item do
something different. For instance, rotate-around-point is one such
action. I this case all points are not treated the same. So its not
really a set of items. And they dont use ctrl-click.
I agree, it can get tricky. Especially when you are doing something
new. Between my TurboCAD, my AnimationMaster and my Visio I got all the
graphics interactions covered. I did at one time have a more
complicated interaction, but I reworked the whole thing so it could be
simpler. It now takes longer to do, but I think we gotta strive to keep
it simple.
Good luck m8
CL
Current Time: Sat May 24 07:13:33 EDT 2025
Powered by FUDForum. Page generated in 0.08675 seconds
