Re: Run-Time Workbench not available as option under Eclipse Run menu [message #197097 is a reply to message #197021] |
Thu, 01 March 2007 07:20 |
Originally posted by: nugaee.SPAMtlen.pl
Martin Thompson wrote:
> I don't have this available. Eclipse 3.2.
> Any ideas? Is this some plug-in that I have to install? If so, what is the
> jar file?
> Martin
do you mean running eclipse application ?
then you must configure your application (with propably yours plugins)
using Run... option.
if you mean opening new eclipse windows it can be done from Windows menu
-> new window
regards
bartek michalik
Re: Run-Time Workbench not available as option under Eclipse Run menu [message #197294 is a reply to message #197240] |
Thu, 01 March 2007 19:40 |
Originally posted by: wharley.bea.com
"Martin Thompson" <thompsma@aecl.ca> wrote in message
news:es6vsf$unh$1@utils.eclipse.org...
>I just want to test an example RCP application from within Eclipse before
> compiling it into a standalone Java application. The instructions in
> Scarpino's "SWT/JFace In Action" book read ...
> 1) In the Eclipse main menu, choose the Run option under the Run menu item
> 2) In the left pane, select the Run-time Workbench option
> My problem is that no such "Run-time Workbench" option exists...
I think that's the same thing as Eclipse Application.
FUDForum. Page generated in 0.08211 seconds
