Files and folders includding into project ? [message #196232] |
Mon, 26 February 2007 12:50 |
Originally posted by: smieci79.o2.pl
I need/want to add couple text files into the project and included them
to jar file. I copied them to:
~/WorkSpace/project/folder_to_include/some_files
In Eclipse->Package Explorer I can see the folder and files in it.
But i don't know how to open such files.
Could give me any tip, will be grateful.
Re: Files and folders includding into project ? [message #196240 is a reply to message #196232] |
Mon, 26 February 2007 12:56 |
Originally posted by: jakub.jurkiewicz.gmail.com
Try clicking right mouse button on the file and choose Open or Open with.
To create a jar file you have to use Export Wizard -> Java -> Jar
Hope it helps
Jakub Jurkiewicz
> Thanks
Re: Files and folders includding into project ? [message #196248 is a reply to message #196240] |
Mon, 26 February 2007 13:04 |
I've already done that but the problem is that i don't know how to open
such files from java code, i can access them by giving full path but it
will change after i move project to another machine so i need to use
path inside my future jar file something like (./folder/file ) ??
> Hope it helps
> Jakub Jurkiewicz
>> them to jar file. I copied them to:
>> Thanks
Re: Files and folders includding into project ? [message #196255 is a reply to message #196248] |
Mon, 26 February 2007 13:12 |
Krzysztof,
Maybe you'd be better to put these files in the same folder as the class
that will load them and then use Xyz.class.getResource("...") to access
them. If you are building a plugin, you could use Bundle's
getEntry/getResource method to access them anywhere in the bundle/jar;
be sure to use the build.properties to specify that the folder should
end up in the binary jar.
> open such files from java code, i can access them by giving full path
> but it will change after i move project to another machine so i need
> to use path inside my future jar file something like (./folder/file ) ??
>> with.
>> Hope it helps
>> Jakub Jurkiewicz
>>> Thanks
Re: Files and folders includding into project ? [message #196263 is a reply to message #196248] |
Mon, 26 February 2007 13:14 |
So I guess that it is more like java basics question rather than eclipse
question.
However, I googled and found this topic:
http://www.daniweb.com/techtalkforums/thread21906.html
Also here: http://javaworkshop.sourceforge.net/chapter5.html is some
interesting information.
Look here also:
http://java.sun.com/j2se/1.4.2/docs/guide/resources/resource s.html
Hope this helps :)
Jakub Jurkiewicz
>> Hope it helps
>> Jakub Jurkiewicz
>>> Thanks
Re: Files and folders includding into project ? [message #196271 is a reply to message #196263] |
Mon, 26 February 2007 13:24 |
Thanks a lot.
That was exactly what I was looking for.
> question.
> Look here also:
> Hope this helps :)
> Jakub Jurkiewicz
>>> with.
>>> Hope it helps
>>> Jakub Jurkiewicz
>>>> Thanks
FUDForum. Page generated in 0.08044 seconds
