cannot import swt project [message #196025] |
Sun, 25 February 2007 00:29 |
Originally posted by: manraygun.verizon.net
Using the Import Wizard, when I select the zip archive that I was directed
to download, the wizard doesn't show any projects to select and the finish
button remains disabled. What's the problem?
Re: cannot import swt project [message #196185 is a reply to message #196025] |
Mon, 26 February 2007 09:34 |
Originally posted by: jakub.jurkiewicz.gmail.com
Did you unpack the archive? What is inside?
regards,
Jakub Jurkiewicz
> directed to download, the wizard doesn't show any projects to select and
> the finish button remains disabled. What's the problem?
Re: cannot import swt project [message #196376 is a reply to message #196185] |
Mon, 26 February 2007 22:16 |
Well, according to the tutorial, I don't need to unpack the zip archive to
import it. However, I did unpack it and it contains a .classpath file, a
project file, four dll files, a src archive and some documentation.
Re: cannot import swt project [message #196433 is a reply to message #196376] |
Tue, 27 February 2007 07:43 |
The problem can be, that you've got already a project with the same name
in your workspace (then projects from the archive aren't shown on the
available projects list in the wizard).
If this is not the case, please look to the <workspace>/.metadata/.log
file and look if there are any information, that could help to get what
the problem is.
regards,
Jakub Jurkiewicz
> to import it. However, I did unpack it and it contains a .classpath
> file, a project file, four dll files, a src archive and some documentation.
FUDForum. Page generated in 0.08523 seconds
