Re: Class Loader problem [message #194807 is a reply to message #194782] |
Sat, 17 February 2007 13:40 |
Zakir,
You really need to provide more context to your questions. I.e., put in
as much effort asking the question as others end up putting in answering
them. My theory would be that you are working with a plugin project and
rather than editing the MANIFEST.MF to add a dependency you've updated
the build path directly by the project's properties in order to fix your
compile time problem only to have the same problem show up again at
runtime. I would again suggest using plugin projects consistently and
to only edit the MANIFEST.MF when you need to make classpath changes.
Don't push the river, it flows by itself...
zakir wrote:
> I am working with a java project, I had added one plugin as a jar to
> my project.
> I am getting classloader exception... regarding class not found...
> Can you plz suggest me how to overcome this one.....
> Zakir
FUDForum. Page generated in 0.04673 seconds
