userspace exception [message #194656] |
Fri, 16 February 2007 17:00 |
Originally posted by: allane.laguna-indutries.com
I recently installed eclipse 3.2 on a gentoo Linux box.
root user can invoke eclipse without problem yet user gets exception at
startup. I have checked the usual: file permissions, read access to files
and directories - this all looks normal.
The exception was written to log file and contents follows:
!SESSION 2007-02-16 09:09:42.823
eclipse.buildId=M20060629-1905
java.version=1.4.2_13
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.core.runtime 4 0 2007-02-16 09:09:45.017
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs;
bundle-version="[3.2.0,4.0.0)"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:329)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1037)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:573)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:455)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
!ENTRY org.eclipse.osgi 4 0 2007-02-16 09:09:45.037
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/
was not resolved.
!ENTRY org.eclipse.osgi 4 0 2007-02-16 09:09:45.075
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:65)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2007-02-16 09:09:45.083
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-02-16 09:09:45.083
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2007-02-16 09:09:45.084
!MESSAGE Missing required bundle
org.eclipse.core.contenttype_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
org.eclipse.equinox.preferences_[3.2.0,4.0.0).
org.eclipse.equinox.registry_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2007-02-16 09:09:45.085
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-02-16 09:09:45.085
!MESSAGE Bundle
[3] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2007-02-16 09:09:45.086
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2007-02-16 09:09:45.087
!MESSAGE Missing optionally required bundle
org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
****** END STACK DUMP
I checked for file <eclipse_home>/plugins/org.eclipse.core.jobs but found
only /plugins/org.eclipse.core.jobs_3.2.0.v20060603.jar, whichi I must
assume is correct.
Any help on this problem would be appreciated.
FUDForum. Page generated in 0.08180 seconds
