Re: Updating the About Text of RCP [message #194636 is a reply to message #194613] |
Fri, 16 February 2007 15:11 |
Originally posted by: jacek.pospychala.pl.ibm.com
Hi Zakir,
sure you can, aboutText is stored in plugin.xml file found in your
plugin jar. Unzip it, change the text and that's it :)
zakir napisał(a):
> Hi ,
> I am working with an RCP now.
> I had created an RCP out of a plugin...
> I have contributed aboutText of RCP in the plugin...
> write now after extracting the RCP , can i update the AboutText with out
> going into the development environment....
> Zakir
Re: Updating the About Text of RCP [message #194760 is a reply to message #194682] |
Sat, 17 February 2007 08:07 |
Zakir,
then the question is, what is the RCP you are trying to change. If it's
created using default Eclipse wizard, then the about text is defined in
plugin with product definition. There is a fragment like this:
<extension id="product" point="org.eclipse.core.runtime.products">
<product application="MyRCP.application" name="RCP Product">
<property name="aboutText" value="CHANGE ME! :)">
</property>
Please also verify that the product you run is the same, you have just
modified. For example, if you unzip the plugin with product, modify the
above fragment, then don't forget to remove the original plugin jar
file, so the RCP will use unzipped directory.
Let me know if that has worked for you.
Jacek Pospychala
zakir napisał(a):
> Hi ,
> I have tried changing in...plugin.xml
> I had also tried by changing the product file....
> But this is not working.....
> Is there any alternate way to perform this task....
> Thanks in advance....
> Zakir
FUDForum. Page generated in 0.05454 seconds
