Re: how to select the elements in a table [message #194354 is a reply to message #194331] |
Thu, 15 February 2007 11:49 |
Zakir,
I think (but am not sure) that org.eclipse.swt.custom.TableCursor might
help (although I've never tried it).
zakir wrote:
> I am having a table with 4 columns...
> I want to select the elements in the table..........
> but i am not able to select... any element from other than 1st column....
> Could you plz give me any suggestions..
> Zakir
Re: how to select the elements in a table [message #194493 is a reply to message #194354] |
Thu, 15 February 2007 13:20 |
Originally posted by: csae7511.uibk.ac.at
When you instantiate the table with SWT.FULL_SELECTION, you are able to
select the whole row.
Does this solve your problem?
Stefan
Ed Merks schrieb:
> Zakir,
>> Regards,
>> Zakir
Re: how to select the elements in a table [message #194533 is a reply to message #194509] |
Thu, 15 February 2007 18:03 |
Originally posted by: dmsubs.NOSPAM.consertum.com
You will need to create a Listener for SWT.MouseDown on your table. In your
listener, you will then need to check if the co-ordinates lie within an editable
cell. Here is a snippet to get you started:
table.addListener(SWT.MouseDown, new Listener() {
public void handleEvent(Event event) {
Rectangle clientArea = table.getClientArea();
Point pt = new Point(event.x, event.y);
int index = table.getTopIndex();
while (index < table.getItemCount()) {
boolean visible = false;
final TableItem item = table.getItem(index);
Rectangle rect = item.getBounds(EDITABLECOLUMN);
if (rect.contains(pt)) {
setEditors(tEditor, EDITABLECOLUMN, item);
if (!visible && rect.intersects(clientArea)) {
visible = true;
if (!visible)
return;
index++;
setEditors is a function I have written to create an editable Text field over a
cell. EDITABLECOLUMN is a constant of mine as I only ever want to allow editing
on a single column.
HTH
Derek
zakir wrote:
> HI Stefan,
> I want to select only particular cell in a table.........not whole row...
> Could you please suggest me regarding this...
> Zakir
FUDForum. Page generated in 0.09240 seconds
