How can I open a file in external editor from Eclipse? [message #193995] |
Wed, 14 February 2007 12:17 |
Originally posted by: martin.hanzalek.gmail.com
I'm using Eclipse as IDE, but for some file types I'd like to use Vim
editor - because of its syntax highlighting and fast editing features.
What I do now is to drag file from eclipse Package explorer over Vim
editor, edit the file and refresh the file list in Eclipe. Which is kind
of clumsy...
Is there any way how to add someting like "Edit with Vim" into Eclipse
file context menu? For instance by right-clicking the file in
PackageExplorer.
I tried viPlugin for Eclipse, but it is not what I need - namely it lacks
syntax highlighting support.
Thanks for an answer, Martin.
Re: How can I open a file in external editor from Eclipse? [message #194021 is a reply to message #193995] |
Wed, 14 February 2007 13:30 |
> of clumsy...
you can set editor for file extension:
Windows->Preferences
General-> Editors -> File Associations
bartek michalik
Re: How can I open a file in external editor from Eclipse? [message #194058 is a reply to message #194013] |
Wed, 14 February 2007 15:07 |
Originally posted by: eclipse5.rizzoweb.com
Krzysztof Daniel wrote:
> Right click on resource -> open with -> other -> external programs and
> eventually browse.
Is that a new menu path in 3.3? Because it does not work that way up to
and including 3.2.1. For those versions you'll have to specify an
external editor for each file extension you want via the Preferences,
under General > Editors > File Associations
Hope this helps,
Eric
Re: How can I open a file in external editor from Eclipse? [message #194066 is a reply to message #193995] |
Wed, 14 February 2007 15:09 |
> lacks syntax highlighting support.
There are responses about how to specify an external editor, but I'd
like to know what kinds of files you are talking about. There are many
Eclipse plug-ins that provide syntax-highlighting editors for numerous
file types, so it is quite possible that you could avoid using the
external editor completely, with the right guidance.
Eric
FUDForum. Page generated in 0.03047 seconds
