Switching between a set of open files? [message #193394] |
Sun, 11 February 2007 21:10 |
Originally posted by: info.nuttijay.org
Hi, i am using eclipse for a while and feel astunnished by that free ide.
Thanx a lot to the developers, would spend them a beer - but than i would
be broke within minutes i figure.
But i have question. Right now i am working in a projekt, have several
files open and just realized, that i have to open up some other files for
doing some changes in the same projekt but under a nother context. can i
switch to another -perspective- or so, keeping the current open files in
memory so that i can get later on back to them?
Dont know how to do that or if i hust missed a feature ?
Cheers
ingo
Re: Switching between a set of open files? [message #193415 is a reply to message #193394] |
Sun, 11 February 2007 21:55 |
Ingo,
Perspectives will share the same open files. Try clicking on the first
icon in the upper right tab; this tab controls all your perspectives and
lets you open new ones.
> ide. Thanx a lot to the developers, would spend them a beer - but than
> i would be broke within minutes i figure.
> for doing some changes in the same projekt but under a nother context.
> can i switch to another -perspective- or so, keeping the current open
> files in memory so that i can get later on back to them?
> Cheers
> ingo
Re: Switching between a set of open files? [message #193433 is a reply to message #193415] |
Mon, 12 February 2007 02:00 |
didnt got me right...
I know what perspectives are and what they are used for... Java, SVN
Exploring et cetera. I want to know if i can save the line of open files
into a buffer, work on a second buffer with different files, go back to
the first buffer and have my set of initialy used files restored...
Is there such a feature ?
Ingo
Re: Switching between a set of open files? [message #193440 is a reply to message #193394] |
Mon, 12 February 2007 02:02 |
Originally posted by: b.muskalla.gmx.net
Such a file-set feature doesn't exist yet in eclipse (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105896) but there is a
plugin to have such a function by Andrei Loskutov (see bug comment #6).
But i really want to point you to Mylar: eclipse.org/mylar
There you can activate a task, work on it and when you switch to another
task, mylar remembers your settings (like opened files) when coming back
to that task.
Hope this helps
Benny
(second time - forgot to add the newsgroup)
> ide. Thanx a lot to the developers, would spend them a beer - but than i
> Cheers
> ingo
Re: Switching between a set of open files? [message #193571 is a reply to message #193394] |
Mon, 12 February 2007 16:46 |
As someone else suggested, Mylar is a nice extension to Eclipse that can
support what you're trying to do.
A simpler approach is to use the menu command Window > New Window which
will open a new Workbench window on the same workspace - the second
window can have different editors, views, and perspectives open than the
original.
Hope this helps,
Eric
FUDForum. Page generated in 0.08591 seconds
