Connecting to MySql 5.0 [message #193207] |
Sat, 10 February 2007 12:01 |
Originally posted by: alnoor20000.yahoo.co.uk
I have got the 3.2.1 eclipse version and MySql 5.0, how do I make a
connection to the database; What plug-ins if any do I need to install.
Any pointers on how do i connect??
Re: Connecting to MySql 5.0 [message #193213 is a reply to message #193207] |
Sat, 10 February 2007 13:17 |
Originally posted by: csae7511.uibk.ac.at
you can use the jdbc drivers prodived by MySQL or use persistency
frameworks like hibernate.
HTH,
Stefan
Jalal schrieb:
> Thanks
Re: Connecting to MySql 5.0 [message #193303 is a reply to message #193207] |
Sun, 11 February 2007 04:10 |
Originally posted by: eclipse5.rizzoweb.com
Jalal wrote:
> Thanks
Honestly, you do not provide enough details about what you want to do.
Do you need to connect from a program you are writing? Do you want a
database "browsing" tool to inspect your db? Etc?
Help us help you - give details of what you're trying to achieve.
Re: Connecting to MySql 5.0 [message #193361 is a reply to message #193303] |
Sun, 11 February 2007 13:49 |
Hi there, Thanks for your reply. What i want to do is, I have a java program
that connects to the MySql database, and retrieve some records from the
table. I would like also to be able to update records in the the tables.(
Running the program through the command line window works fine, the
connection is established and the records are retrieved) but comming to
eclipse, it is just giving me the following error.
java.lang.ClassNotFoundException: com.mysql.jdbc.Driver
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at menu.DisplayAuthors.main(DisplayAuthors.java:26)
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:eqm4s0$hvc$4@utils.eclipse.org...
> Jalal wrote:
>> Thanks
> Honestly, you do not provide enough details about what you want to do. Do
> you need to connect from a program you are writing? Do you want a database
[OT: add jar at runtime] Re: Connecting to MySql 5.0 [message #193561 is a reply to message #193552] |
Mon, 12 February 2007 16:43 |
Originally posted by: hkaest.mro.man.de
"Jesper" wrote:
> right-click your project, choose Properties in the pop-up menu, go to Java
> Build Path, go to the tab Libraries, and click on the button "Add JARs"
> (if the JAR file with the driver is in your project) or "Add External
> JARs" (if you have the JAR file somewhere outside your project).
my problem is not far away from the topic of this thread. That's why i try
to post it here.
I have a plug-in that has the option to store data in a database, that is
not known at development time. The user of the plugin has to declare the
driver and the URL for the connection. That means the jar file has to be
added to the classpath at runtime. Who can i manage this?
Harald
Re: [OT: add jar at runtime] Re: Connecting to MySql 5.0 [message #197457 is a reply to message #197163] |
Fri, 02 March 2007 09:14 |
> Please report your problum as detail. If you wand to connect with java
> and MySQL or C/C++ with MYSQL or PHP with MYSQL. These all things are
> possible. Please write the details.
My need was to connect with java and any database which can be connected
with a jdbc driver. I managed it in the meantime by writting my own
DriverManager and using an URLClassLoader. Like the tool squirrel does.
Thanks for your help.
--Harald
FUDForum. Page generated in 0.09748 seconds
