My help contents does not work [message #193011] |
Fri, 09 February 2007 04:29 |
Originally posted by: bobbyzhu_2001.163.com
I installed Eclipse3.2,but the help contents does not work .when i
click it ,the browser tell me that the webpage cannot be found.it's
there anybody who can tell me how to fix it?
Re: My help contents does not work [message #193068 is a reply to message #193011] |
Fri, 09 February 2007 13:31 |
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Could you post here .log file from your workspace/metadata?
And you can check your firewall settings and help settings in
window->preferences->help->content (checkbox should be unchecked).
I hope it helps
Chris
Re: My help contents does not work [message #193425 is a reply to message #193068] |
Mon, 12 February 2007 01:51 |
!SESSION 2007-02-09 08:57:50.375
eclipse.buildId=M20060921-0945
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 1 2007-02-09 09:00:25.046
!MESSAGE NLS unused message: InstallWizard_TargetPage_size in:
org.eclipse.update.internal.ui.UpdateUIPluginResources
!ENTRY org.eclipse.jface 4 2 2007-02-09 09:04:40.343
!MESSAGE 从插件调用代码时出现问题:“org.eclipse.jface
Re: My help contents does not work [message #193461 is a reply to message #193425] |
Mon, 12 February 2007 08:50 |
Hello there again,
Are those errors just from one session?
If not, please delete your .log file, run eclipse and try to see the
help. Then post here newly created .log file.
Chris
Re: My help contents does not work [message #195550 is a reply to message #193461] |
Thu, 22 February 2007 12:24 |
Originally posted by: viji_chandran.myway.com
u add the following plugins in ur (plugin.xml) dependencies then it'll
work fine
com.ibm.icu
org.apache.ant
org.apache.lucene
org.eclipse.ant.core
org.eclipse.core.commands
org.eclipse.core.contenttype
org.eclipse.core.expressions
org.eclipse.core.jobs
org.eclipse.core.runtime
org.eclipse.core.runtime.compatibility.auth
org.eclipse.core.runtime.compatibility.registry
org.eclipse.core.variables
org.eclipse.equinox.common
org.eclipse.equinox.prefrences
org.eclipse.equinox.registry
org.eclipse.help
org.eclipse.help.appserver
org.eclipse.help.base
org.eclipse.help.ui
org.eclipse.help.webapp
org.eclipse.jface
org.eclipse.osgi
org.eclipse.swt
org.eclipse.swt.win32.win32.x86
org.eclipse.tomcat
org.eclipse.ui
org.eclipse.ui.browser
org.eclipse.ui.forms
org.eclipse.ui.workbench
org.eclipse.update.configuration
FUDForum. Page generated in 0.08118 seconds
