html files [message #192287] |
Tue, 06 February 2007 19:52 |
Originally posted by: emf.NOSPAM.email.com
How does eclipse handle html files? Specifically:
Should I include them in the same package folder or in the project
folder to where the package belongs?
How do I create an html file inside eclipse? Should I open New > File?
How do I edit an html file in eclipse? Is Open With > Text Editor that I
have used the best way?
Eustace
Re: html files [message #192529 is a reply to message #192317] |
Wed, 07 February 2007 15:12 |
Dear Ed.
Thanks for your reply.
On 2007.02.06 15:05 Ed Merks wrote:
> Eustace,
> For EMF we put files like package.html in the appropriate package under
> the "src" folder along with the .java files:
In an eclipse paperback I did see that you can assign separate folders
for .java and .class files, but I haven't applied that yet. Until I do,
I suppose I'll keep the .html files together with the .java and .class
ones in the same package folder.
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/plu gins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/?root=T ools_Project
Wow! I really could not make out what this webpage is about. No text, no
explanation of what's going on... But I am sure it makes good sense for
the developers. If only some of them would apply themselves to
simplifying the whole project to make it more user-friendly... To an
outsider the whole project seems more oriented toward the developer
rather than toward the user.
> I believe the web tools project, http://www.eclipse.org/webtools/
> provides an HTML editor, but I've not used that. Failing that, the text
> editor or an external HTML editor will have to suffice.
Good to know that there is a html editor, but at this point I would
rather not start adding new elements is eclipse - it is complicated
enough as it is. For now and until I feel more at home with eclipse, I
can use the text editor for simple html files and Nvu for more complex ones.
>> I have used the best way?
>> Thanks,
>> Eustace
Re: html files [message #192544 is a reply to message #192529] |
Wed, 07 February 2007 16:38 |
Eustace,
Comments below.
Eustace wrote:
> Dear Ed.
>> Eustace,
>> under the "src" folder along with the .java files:
> do, I suppose I'll keep the .html files together with the .java and
> .class ones in the same package folder.
Even if you set things up so that generated .class files are in a
separate folder, I'm pretty sure you'll still want to keep the javadoc
HTML files in the same folder as the .java files.
> no explanation of what's going on... But I am sure it makes good sense
> for the developers.
It's just a simple web interface to a CVS repository. All Eclipse
source code is accessible in this way.
> If only some of them would apply themselves to simplifying the whole
Simplicity is in the eye of the beholder and is a moving target. I
would assert the following. With respect to any particular technology,
people will fall into one of two camps: Those who don't yet understand
it, and want it to be simpler. And those who do already understand it,
and want more and more and more... This is a never ending battle.
Adding more capabilities will not ever be a simplification.
> To an outsider the whole project seems more oriented toward the
> developer rather than toward the user.
It sounds though like you are a developer... The real problem, I think,
is that the people doing the work are developers and don't have time
left to write lots of nice high-level documentation. (And of course
users don't tend to read the documentation anyway, they just show up
with questions.)
>> text editor or an external HTML editor will have to suffice.
> ones.
Yes, WTP is a pretty big thing to install if all you want is HTML editing.
>>> that I have used the best way?
>>> Thanks,
>>> Eustace
FUDForum. Page generated in 0.08143 seconds
