Manifest.mf Problem [message #190235] |
Fri, 26 January 2007 17:01 |
Originally posted by: ihybily.gmail.com
Hi, I'm encountering a problem with my plugin in eclipse3.2.1
i'm doing the very first example in the book "contributing to
Eclipse".---the easist plug-in "org.eclipse.contribution.hello"
after i wrote these in the plugin.xml
<plugin>
<extension
point="org.eclipse.ui.actionSets">
<actionSet
id="org.eclipse.contribution.hello.actionSet"
label="Hello Action Set">
<action
id="org.eclipse.contribution.hello.HelloAction"
label="Hello">
</action>
</actionSet>
</extension>
</plugin>
i got an error in the MANIFEST.MF
"Plug-ins declaring extensions or extension points must set singleton
attribute to true"
so I added the
singleton:=true
to my
Bundle-SymbolicName: org.eclipse.contribution.hello
Bundle-SymbolicName: org.eclipse.contribution.hello; singleton:=true
I still got the original error. :(
can anyone help?
thanks in advance
amy
Re: Manifest.mf Problem [message #190292 is a reply to message #190235] |
Fri, 26 January 2007 20:11 |
Originally posted by: wharley.bea.com
"amy" <ihybily@gmail.com> wrote in message
news:b441ce7d5a30052a5f151249f41e929e$1@www.eclipse.org...
> attribute to true"
> so I added the singleton:=true to my Bundle-SymbolicName:
If you create a new plug-in project using the "new project" wizard to
specify a "hello world" plug-in, and you inspect its manifest.mf, are there
any relevant differences between that and the one that you created by hand?
Re: Manifest.mf Problem [message #190385 is a reply to message #190292] |
Sat, 27 January 2007 10:18 |
>> attribute to true"
yes i wanted practise by hand as much as possible so i didn't choose the
"create a plug-in using one of the templates"
but the error disapeared after sometime!!!! i don't know why......
at least i can go on now.
Re: Manifest.mf Problem [message #190458 is a reply to message #190385] |
Sun, 28 January 2007 23:18 |
news:3d1911361dc18cb4f3fd5d757524c14c$1@www.eclipse.org...
That's an excellent approach. However, it's often useful to compare your
hand-generated code with what the wizard produces, especially when something
is going wrong.
FUDForum. Page generated in 0.08380 seconds
