Sharing .classpath file and creating classpath variables [message #190120] |
Thu, 25 January 2007 22:22 |
Originally posted by: anf4.cornell.edu
Hello, and thanks in advance for your help.
I'm using Eclipse version 3.1.2, and working in a small team on a project
that uses JDK 1.4.2. This is not my primary JRE, so in my .classpath
file, the following entry is created:
<classpathentry kind="con"
path=" org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.inte rnal.debug.ui.launcher.StandardVMType/JDK
1.4.2 Update 5"/>
I know how to create a classpath variable, but I'm not quite sure how to
create a variable to represent my JDK, so that we can share the .classpath
file in the repository. Does anyone have any ideas on how to go about
this?
Thanks for your help,
Anthony Frasso
Re: Sharing .classpath file and creating classpath variables [message #190249 is a reply to message #190120] |
Fri, 26 January 2007 18:41 |
> project that uses JDK 1.4.2. This is not my primary JRE, so in my
> .classpath file, the following entry is created:
> 1.4.2 Update 5"/>
> .classpath file in the repository. Does anyone have any ideas on how to
> go about this?
In the Installed JREs section of your Preferences, each JRE/JDK is given
a user-editable name. The way to handle different configurations on
different developer machines is to agree on a name for the desired
JRE(s) (just as with a classpath variable) and then have each developer
define a JRE using that name. If you look carefully at the .classpath
entry, you'll see that the JRE name is used as the last part of the path
attribute.
Hope this helps,
Eric
FUDForum. Page generated in 0.07868 seconds
