Help with Project [message #189515] |
Tue, 23 January 2007 13:36 |
Originally posted by: kwenam.tiscali.co.za
Consider the following specification: The staff of a state run clinic in
Krokodildrif needs an application that will allow them to register all
their patients. They need capture the following biographic data of each
patient:
1. Name
2. Surname
3. Gender
4. Nationality
5. National ID
6. Birth Date
7. Contact Number
8. Next of Kin Contact Number
The staff needs to search the patient registry using Name or Surname or
National ID, or a combination of all three. They need to add ne patients,
modify existing patient records and delete existing records.
The Chief software architect at GeoAxon has refined the specification and
added the following:
1. The application must be developed using Java Standard Edition 1.5 or
1.6.
2. The GUI must be implemented using SWT.
3. The GUI must consist of a single panel.
4. Any Relational Database or flat file system may be used, if a
relational database is used a JDBC connector must be shipped with the
product and schema generation scripts supplied.
Re: Help with Project [message #189538 is a reply to message #189515] |
Tue, 23 January 2007 16:38 |
> patient:
> 1. Name
> 2. Surname
> 3. Gender
> 4. Nationality
> 5. National ID
> 6. Birth Date
> 7. Contact Number
> patients, modify existing patient records and delete existing records.
> and added the following:
> or 1.6.
> 2. The GUI must be implemented using SWT. 3. The GUI must consist
> of a single panel.
Consider it considered. Was there a question?
Where is Krokodildrif?
Wayne
Re: Help with Project [message #189824 is a reply to message #189515] |
Wed, 24 January 2007 18:28 |
Originally posted by: eclipse5.rizzoweb.com
I'd be happy to work on this project. My rates range from $50/hour to
$100/hour, depending on the travel required and level of responsibility
assigned. I do not do fixed-bid contracts, so your offer of $0.00 is
rejected.
Eric
> patient:
> 1. Name
> 2. Surname
> 3. Gender
> 4. Nationality
> 5. National ID
> 6. Birth Date
> 7. Contact Number
> or 1.6.
> of a single panel.
Re: Help with Project [message #189938 is a reply to message #189824] |
Thu, 25 January 2007 12:54 |
> rejected.
> Eric
Those are some pretty reasonable consulting rates. Are you some kind of
charity?
Wayne
Re: Help with Project [message #190045 is a reply to message #189938] |
Thu, 25 January 2007 18:56 |
>> responsibility assigned. I do not do fixed-bid contracts, so your
>> offer of $0.00 is rejected.
>> Eric
> charity?
> Wayne
Yes, I am in some ways ;-) For example, I spend waaay too much time
hanging out on these groups ;-)
Still, your response is interesting. Where I live (Tampa, FL) that is
the market range (actually, it has been quite a while since anyone I
know has actually pulled $100/hour). I wonder if it is just this market,
or what...? Like I said, it does depend (a lot) on amount of travel.
Eric
Re: Help with Project [message #190074 is a reply to message #190045] |
Thu, 25 January 2007 21:47 |
>>> Eric
>> of charity?
>> Wayne
> Eric
I'm hardly qualified to say. I've always worked for others who take care
of setting consulting rates.
Wayne
FUDForum. Page generated in 0.12181 seconds
