Home » Newcomers » Newcomers » Plugin 'org.eclipse.pde.ui' not found
Plugin 'org.eclipse.pde.ui' not found [message #189139] |
Sat, 20 January 2007 13:02 |
Originally posted by: cwruskamp.gmail.com
I am a complete newcomer to Eclipse. My PC runs Windows XP Pro with all
patches, a firewall, anti-virus and anti-other stuff.
Using 7-zip I installed (unzipped) eclipse-platform-SDK-3.2.1-win32.zip
followed by eclipse-JDT-3.2.1.zip, emf-sdo-xsd-SDK-2.2.1.zip,
emft-ocl-runtime-1.0.1.zip, GEF-ALL-3.2.1.zip, GMF-sdk-1.0.2.zip and
uml2-2.0.2.zip. After starting Eclipse.exe for the first time I only
checked the "Automatically select mirrors" in the Install/Update screens.
After starting the "Search for updates of the currently installed
features" a pop-up message is displayed "network connection problems
encounter during search" and after clicking OK I get following (detailed)
error message:
{quote}
The current configuration contains errors and this operation can have
unpredictable results.
Graphical Modeling Framework Runtime
(1.0.2.v20061027-1200-gW3quV5alH1G8qp) requires feature
"org.eclipse.emf.query (1.0.0)", or compatible.
Graphical Modeling Framework SDK (1.0.2.v20061027-1200-wTCA_vEfmbNQG87)
requires plug-in "org.eclipse.pde.ui".
{end-of-quote}
Clicking the "Select Required" option did not have any effect whatsoever
I found and installed/unzipped emft-query-sdk-1.0.0.zip, restarted eclipse
with the -initialise option, started the update session again, this time
resulting in the error-message:
{quote}
"org.eclipse.emf.validation (1.0.0)", or compatible.
{unquote}
Once again, clicking the "Select Required" option did not have any effect
whatsoever.
Especially the "org.eclipse.pde.ui" seems to be a rather elusive plugin, I
have not been able to find it. What can I do the resolve this?
Kees Ruskamp
Re: Plugin 'org.eclipse.pde.ui' not found [message #189237 is a reply to message #189139] |
Sun, 21 January 2007 21:02 |
Paul A. Rubin Messages: 188 Registered: July 2009 |
> (detailed) error message:
> {quote}
> {end-of-quote}
> eclipse with the -initialise option, started the update session again,
> this time resulting in the error-message:
> {quote}
> {unquote}
> effect whatsoever.
> I have not been able to find it. What can I do the resolve this?
Odd that you would not have it: it's part of the Plug-in Development
Environment, and should have been included in the Eclipse SDK download
(see, for instance, http://www.eclipse.org/pde/). If you go to
Help->Software Updates->Manage Configuration and expand the tree on the
left, do you find an entry for 'Eclipse Plug-in Development Environment
3.2.1.' (followed by what I think is the security key to Bill Gates's
PDA)? If yes, does Show Properties->Status indicate proper configuration?
Also, check the plug-ins directory under the Eclipse root for a file
(not folder) named something like
'org.eclipse.pde.ui_3.2.1.v20060816-0800.jar'. If it's not there, my
(uninformed) guess would be that something went awry when you unzipped
the SDK. (There've been reports of problems using Windows's internal
zip capability, I think.) Try reinstalling using WinZip or similar
(ZipCentral works for me).
HTH,
/Paul
Re: Plugin 'org.eclipse.pde.ui' not found [message #189487 is a reply to message #189237] |
Tue, 23 January 2007 08:22 |
Paul Rubin wrote:
>> all patches, a firewall, anti-virus and anti-other stuff.
>> eclipse-platform-SDK-3.2.1-win32.zip followed by
>> {quote}
>> (1.0.2.v20061027-1200-wTCA_vEfmbNQG87) requires plug-in
>> {end-of-quote}
>> {quote}
>> {unquote}
>> effect whatsoever.
>> plugin, I have not been able to find it. What can I do the resolve this?
> HTH,
> /Paul
Paul,
As expected I did not find the 'org.eclipse.pde.ui...etc' file. I
followed your advice and did start again. This time I did stop certain
background services first, unzipped the Eclipse-SDK file and used the
'Search for new features' to download and install the selection I
wanted. So far I only have had similar errors using the 'search for
updates' with EMF (error 403) as reported elsewhere, A bug has also been
filed for this.
Thanks for your help
Kees Ruskamp
Current Time: Fri Apr 19 21:59:09 GMT 2024
Powered by FUDForum. Page generated in 0.07921 seconds
