cannot resolve [message #188294] |
Tue, 16 January 2007 02:36 |
Originally posted by: starkweatherd.cox.net
hello,
I'm having trouble getting my project to recognize some library .jar files
for a java project. I have some jar files in a /lib directory that I put
right in the project directory itself. I set the classpath variables using
PROJECT --> PROPERTIES -> BUILDPATH etc. (I tried adding it a few
different ways but to no avail: a variable, external jar, jar file,
etc. ) Every time i get the following errror message: "the import [package
name] cannot be resolved" . Also, in the package view, the the packages
have a red error marking on the icons. Does anyone know how I can resolve
this?
thanks,
dgs.
Re: cannot resolve [message #188355 is a reply to message #188294] |
Tue, 16 January 2007 09:21 |
Originally posted by: dmsubs.NOSPAM.consertum.com
Do you need to add it as a dependency?
Derek
David Starkweather wrote:
> hello,
> this?
> thanks,
> dgs.
Re: cannot resolve [message #188421 is a reply to message #188355] |
Tue, 16 January 2007 14:20 |
I added it to the Project Buildpath. It is a component jar file that my
project needs to use. It is not another project that I created, just an
external component. I'm not aware of anything else I was supposed to do, but
i'll look into adding it as a dependency as well.
thanks,
dgs.
"Derek Morris" <dmsubs@NOSPAM.consertum.com> wrote in message
news:eoi5ep$m91$2@utils.eclipse.org...
> Derek
>> hello,
>> files for a java project. I have some jar files in a /lib directory that
>> I put right in the project directory itself. I set the classpath
>> variables using PROJECT --> PROPERTIES -> BUILDPATH etc. (I tried
>> adding it a few different ways but to no avail: a variable, external
>> jar, jar file, etc. ) Every time i get the following errror message:
>> "the import [package name] cannot be resolved" . Also, in the package
>> view, the the packages have a red error marking on the icons. Does
>> anyone know how I can resolve this?
>> thanks,
>> dgs.
Re: cannot resolve [message #188429 is a reply to message #188421] |
Tue, 16 January 2007 14:32 |
ok, i got it now. It turns out that the problem was that the jar file i was
adding on the build path was contained within another jar file. So, i had
to un-jar it first and then add the contained jar file tdo the classpath. I
was adding the larger jar file to the classpath without un-jar'ing it first.
thanks,
dgs.
"David Starkweather" <starkweatherd@cox.net> wrote in message
news:eoimuo$na8$1@utils.eclipse.org...
>but i'll look into adding it as a dependency as well.
> thanks,
> dgs.
>> Derek
>>> hello,
>>> that I put right in the project directory itself. I set the classpath
>>> thanks,
>>> dgs.
Re: cannot resolve [message #192242 is a reply to message #191947] |
Tue, 06 February 2007 16:41 |
Originally posted by: eclipse5.rizzoweb.com
Victor Eijkhout wrote:
> My problem is similar. I try to compile a source that has "import
> com.foo.bar.*" and I have a directory structure com/foo/bar/* somewhere
> in my disc. But I can't figure out how to add it.
> Project > Properties > Java Build Path > Libraries.
> And then?
If the directory containing the classes is in a Project in Eclipse, you
can use the "Add class folder..." button to include it.
If the classes are not in an Eclipse project, you have a couple of options:
A) Make a JAR (or ZIP) out of the classes directory structure and add
that to your build path. Most code libraries are shipped as a JAR anyway...
B) Add the classes directory as a Linked Resource to your Project in
Eclipse. (Search the Eclipse Help Contents for "linked resources" to
learn the details.) Then you can use the "Add classes folder..." button
to include that on your build path.
Hope this helps,
Eric
FUDForum. Page generated in 0.06353 seconds
