Eclipse install??? [message #186206] |
Sun, 31 December 2006 15:40 |
Originally posted by: chrisnancy.earthlink.net
I am completely new to Eclipse and I've just downloaded 3.2.1, but can't
find any instructions on how to install the software. I just have a big
zip file sitting on my PC. Can someone please point me to instructions?
Chris
Re: Eclipse install??? [message #186221 is a reply to message #186206] |
Sun, 31 December 2006 17:29 |
Randy D. Smith Messages: 394 Registered: July 2009 |
Chris wrote:
> Hello,
> Thanks
> Chris
Unzip the big zip file, using a "good" unzipper (e.g., WinZip, NOT the
built-in Windows unzipper).
Make sure you have a Java JRE available on your path that is 1.4.2 or
greater (you can open a Command Prompt, and try "java -version" to see
if you're good to go).
Then, if you browse to the unzipped directory, you should find an
eclipse.exe inside the eclipse subdirectory. That should start eclipse
for you.
If you have a 1.4.2+ JRE, but it's not on your path, you can (1) copy
the eclipse.exe shortcut to your desktop, (2) edit the Properties to add
"-vm /path/to/jre/bin/java.exe", and (3) double-click to run as above.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
FUDForum. Page generated in 0.02763 seconds
