New Plugin for code generation [message #185688] |
Tue, 26 December 2006 17:10 |
Angelo ZERR Messages: 122 Registered: July 2009 |
I'm developping a Plugin Akrogen for generate any code, that you can found
at http://akrogen.sourceforge.net/. Akrogen Plugin looks like EclipseWork,
but it
- can generate any component of your Application
- Freemarker and XSL are today the template engine implemented.
- XML is the model which can be merge with a template.
Akrogen give you serveral features :
- XML component to describe your WizardPage (parameters of your template
and template to use when user click to the Finish Button).
- XML Wizard which is composed with serveral XML Component. You can
synchronize paramter of one component with other.
Today you use XML Mapping hibernate file to start your generation. So with
this XML file you can generate simple component like DAO, ....but too a
XML PageConfig wich is Akrogen XML description of your page (page for
CRUD, List,...)
Plugin is not finished and my documentation is very poor, but I'm
seraching developers which will be motivate to help me and discuss about
code generation.
Thank you for your answer.
Regards Angelo
FUDForum. Page generated in 0.15828 seconds
