Home » Eclipse Projects » SWTBot » Table not doubleclicked
Table not doubleclicked [message #17504] Thu, 22 January 2009 12:47 Go to next message
I have trouble performing a doubleclick on a Table widget.
bot.table().doubleClick(3, 0);
It behaves just like a "select".
I executed setFocus before the doubleclick, but it does not help.
I'm not sure if it is a bug or not. Has anyone succeded in a double click?
I looked in SWTBotTable.class and it seems ok
in AbstractSWTbot.class I see
protected void doubleClickXY(int x, int y) {
log.debug(MessageFormat.format("Double-clicking on {0}", widget));
notify(SWT.MouseEnter);
notify(SWT.MouseMove);
notify(SWT.Activate);
notify(SWT.FocusIn);
notify(SWT.MouseDown, createMouseEvent(x, y, 1, SWT.BUTTON1, 1));
notify(SWT.MouseUp);
notify(SWT.Selection);
notify(SWT.MouseDoubleClick, createMouseEvent(x, y, 1, SWT.BUTTON1, 2));
notify(SWT.MouseHover);
notify(SWT.MouseExit);
notify(SWT.Deactivate);
notify(SWT.FocusOut);
log.debug(MessageFormat.format("Double-clicked on {0}", widget));
I was wondering if it is ok that 2 events are fired?
Re: Table not doubleclicked [message #17625 is a reply to message #17504] Mon, 26 January 2009 09:53 Go to previous messageGo to next message
Finally, it seems not to come from swtbot.
In fact my app has got two object
a table (SWT)
a tableviewer org.eclipse.jface.viewers.TableViewer
The doubleclick listener is set on tableviewer not on the table.
Any idea how I can get swtbot able to simulate a doubleclick on a
Tableviewer?
Thanks in advance
Re: Table not doubleclicked [message #17637 is a reply to message #17625] Mon, 26 January 2009 12:24 Go to previous messageGo to next message
A TableViewer provides for MVC and uses a Table underneath to display
things.
It is very much possible that SWTBot is broken in this case. There's an
open bug about double clicks on tree items
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=259908), I guess it may
have infestations in a table as well.
-- Ketan
On 26/1/09 20:23, Marc wrote:
> a table (SWT)
> Tableviewer?
> Thanks in advance
Re: Table not doubleclicked [message #21786 is a reply to message #17637] Mon, 16 February 2009 05:01 Go to previous messageGo to next message
I've looked at the bug you mentioned, but I got a bit lost, it doesn't
seem to deal with jface, does it?
I've confirmed my problem:
- an RCP app have a jface TableViewer (with a swt Table attached).
- a doubleclick listener is set on the tableviewer not on the table
- the swtbot "bot.table().doubleClick(x,y)" notifies the table but as no
effect on the tableviewer.
I've confirmed the last point by adding a doubleclick listener directly on
the table, swtbot triggers it well.
I've looked for a work around but found nothing, mainly because I didn't
find any "notifyListeners" like method on jface TatbleViewer.
If someone has an idea on how to programmaticaly fire an double click
event on this TableViewer, I'd be glad to know it.
Marc
> things.
> -- Ketan
>> a table (SWT)
>> Tableviewer?
>> Thanks in advance
Re: Table not doubleclicked [message #21830 is a reply to message #21786] Mon, 16 February 2009 05:25 Go to previous messageGo to next message
My workaround is
UIThreadRunnable.asyncExec(bot.getDisplay(), new VoidResult() {
public void run() {
table.widget.notifyListeners(SWT.DefaultSelection,
new Event());
Re: Table not doubleclicked [message #22183 is a reply to message #21830] Mon, 16 February 2009 08:46 Go to previous messageGo to next message
that did not work for me. It could trigger the Table but did nothing on
the TableViewer.
code I use:
bot.table(0).select(3); //to be sure one item is selected
final SWTBotTable theTable;
theTable = bot.table(0);
public void run() {
theTable.widget.notifyListeners(SWT.MouseDoubleClick,
new Event());
Marc
hugulas chen wrote:
> My workaround is
> public void run() {
> new Event());
Re: Table not doubleclicked [message #22541 is a reply to message #22183] Mon, 16 February 2009 21:49 Go to previous messageGo to next message
Hi Marc,
Have you try SWT.DefaultSelection instead of SWT.MouseDoubleClick?
I found my tables and trees are listening the DefaultSelection and
Selection instead of MouseDoubleClick and MouseClick. swtbot does not fire
these events.
Marc wrote:
> the TableViewer.
> code I use:
> public void run() {
> new Event());
> Marc
> hugulas chen wrote:
>> My workaround is
>> public void run() {
>> new Event());
Re: Table not doubleclicked [message #22585 is a reply to message #22541] Tue, 17 February 2009 03:37 Go to previous messageGo to next message
It worked!
thank you very (!) much.
Sorry I first thought you put DefaultSelection by mistake, and I changed
it to
MouseDoubleClick. Thanks for correcting me.
Is there already a bugzilla about that?
If not, we should create one.
Bye
Marc
hugulas chen wrote:
> Hi Marc,
> these events.
> Marc wrote:
>> the TableViewer.
>> code I use:
>> public void run() {
>> new Event());
>> Marc
>> hugulas chen wrote:
>>> My workaround is
>>> public void run() {
>>> new Event());
Re: Table not doubleclicked [message #22628 is a reply to message #22585] Tue, 17 February 2009 04:44 Go to previous message
Answering to myself...
http://book.javanb.com/swt-the-standard-widget-toolkit/ch09l ev1sec2.html
I found this page with the following:
9.2.29 Table Events
SWT.DefaultSelection (SelectionEvent)
The SWT.DefaultSelection event (typed event SelectionEvent) is sent
whenever the user performs the platform-specific operation that indicates
default selection. On most platforms, default selection occurs when the
user double-clicks on an item or presses the <Enter> key.
I now see the link with the buzilla Ketan had mentionned:
Marc
Previous Topic:Toolbar button API does not work consistently
Next Topic:Open perspective
Current Time: Tue Jul 22 15:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.04416 seconds
