Servlet "upload" not found [message #184967] |
Tue, 19 December 2006 17:23 |
Originally posted by: dwiltz.sbcglobal.net
Installed the Starter Kit for JBoss Eclipse IDE. Downloaded JBoss JDPM
starter kit and started jbpm server (localhost:8080/jbpm). When trying to
deploy a process ("simple" from the base installation), it appears the
"upload" servlet is not on the server. Am using the deployment from
inside Eclipse. Manually tried to find the jsp or servlet on the server
using URL and it is not there. The following message is logged:
java.io.FileNotFoundException: http://localhost:8080/jbpm/upload
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(U nknown
Source)
at org.jbpm.ui.util.ProcessDeployer.deployProcessWithServlet(Un known
Source)
at org.jbpm.ui.util.ProcessDeployer.access$3(Unknown Source)
at org.jbpm.ui.util.ProcessDeployer$1.run(Unknown Source)
I'm sure someone has run into this before. I'm using jbpm 3.1.1. Thank
you very much for any help.
Dave
Re: Servlet "upload" not found [message #185019 is a reply to message #184967] |
Tue, 19 December 2006 21:33 |
> to deploy a process ("simple" from the base installation), it appears
> the "upload" servlet is not on the server. Am using the deployment from
> Source)
> Source)
I believe JBoss IDE has their own forums where this question would be
better served.
Hope this helps,
Eric
FUDForum. Page generated in 0.08147 seconds
