Removing imported libraries 3.2 [message #183216] |
Wed, 06 December 2006 14:34 |
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
I'm using Eclipse 3.2 for a j2ee webapp. I imported a couple of .jar
files into the webcontent/web-inf/lib folder, and they then appeared up
under "Java Resources"/Libraries/Web App Libraries (and NOT inder web-
inf/lib!. And it works fine debugging.
Now, I want to delete these libraries and put those jars as dependent
projects to make modifications easier, and it won't let me delete them
from anywhere I've found. If I right-click on them, "delete" is
disabled. If I go into the project properties | java build path |
Libraries and select them there, again "remove" is disabled.
How do I remove these libs from my project???
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Removing imported libraries 3.2 [message #183492 is a reply to message #183216] |
Fri, 08 December 2006 13:23 |
In article <MPG.1fe09f0ed404838b9896ad@news.eclipse.org>,
ns_dkerber@ns_WarrenRogersAssociates.com says...
Nobody has any suggestions? I created a new project and imported the
files from the old one, and am running into the same thing.
FUDForum. Page generated in 0.09884 seconds
