3.1 vs. 3.2? [message #182175] |
Wed, 29 November 2006 17:48 |
Originally posted by: rjtescher.netscape.net
Yesterday I downloaded and installed 3.2 into a separate
directory from 3.1.
3.2 appears to be working fine, is there any reason to
keep the 3.1 directory around?
I have been [ab]using
Eclipse for over a year, but still consider myself a
"newcomer".
As I keep my the workspace in a separate directory from
either version, is there anything from my old directory
I should copy over?
Re: 3.1 vs. 3.2? [message #182556 is a reply to message #182183] |
Fri, 01 December 2006 18:13 |
Originally posted by: eclipse5.rizzoweb.com
Randy D. Smith wrote:
>> directory from 3.1.
>> keep the 3.1 directory around? I have been [ab]using
>> "newcomer".
>> I should copy over?
> The only think I would recommend is to Export... => Preferences and save
> all into a file that you keep before removing 3.1
You may also want to take note of any thrid-party plugins that you might
have installed into 3.1, go find out if they have 3.2-compatible
versions of them and install in your 3.2
Hope this helps,
Eric
FUDForum. Page generated in 0.44289 seconds
