Home » Eclipse Projects » Plugin Development Environment (PDE) » Finding the Plugins directory
Finding the Plugins directory [message #17161] Mon, 18 August 2008 23:37 Go to next message
Originally posted by: richardepsilonhughes.gmail.com
Is there a straightforward way to find the plugins directory as a File
object from a plugin, so as to directly alter it's contents?
Re: Finding the Plugins directory [message #17273 is a reply to message #17161] Tue, 19 August 2008 13:17 Go to previous message
Are you trying to get the plugins directory or your bundle?
There is FileLocator.getBundleFile() from org.eclipse.core.runtime.
However, there is no real restriction that says your bundle will be in
the main plugins directory.
There is also Platform.getInstallArea() which generally returns the
eclipse folder.
-Andrew
Re: Finding the Plugins directory [message #577078 is a reply to message #17161] Tue, 19 August 2008 13:17 Go to previous message
eclipse folder.
-Andrew
Previous Topic:Project Explorer view does not show loaded project
Next Topic:close editor when delete occurs
Current Time: Tue Jul 22 15:52:17 EDT 2025
Powered by FUDForum. Page generated in 0.25619 seconds
