Changing and deploying Callisto plugins [message #180753] |
Fri, 17 November 2006 16:08 |
Armin Mueller Messages: 33 Registered: July 2009 |
Member |
what is the right approach to deploy a modified plugin which was
originally installed as part of a Callisto feature ?
Let's take org.eclipse.gmf.ecore.editor_1.0.1.v20060919-0800.jar as an
example. I've modified and rebuilt that plugin from CVS sources. Using
the qualifier token in the plugin.xml version, I get a file like this:
org.eclipse.gmf.ecore.editor_1.0.1.200611171638.jar
If I simply copy that into the plugins folder, the configuration manager
complains:
Plug-in: "org.eclipse.gmf.ecore.editor" version: "1.0.1.v20060919-0800"
referenced by this feature is not included at runtime. Runtime includes
plug-in version "1.0.1.200611171638".
plug-in version "1.0.1.v20060919-0800" supplied by feature "Graphical
Modeling Framework (Callisto Edition)" version
"1.0.1.v20060926-1100-ahKKnvqJFLT8ny2".
I don't need to rebuild the entire GMF feature for this minor update, do I ?
Thanks in advance,
Armin
FUDForum. Page generated in 0.04950 seconds
