Home » Newcomers » Newcomers » Emacs Select Multiple Lines
Emacs Select Multiple Lines [message #180344] Wed, 15 November 2006 16:10 Go to next message
Originally posted by: spurcell.ilevy.com
hello,
I have the emacs plug in installed, and I have a question. With my old
command line emacs, I used to be able to issue a [ mark (highlight) area
of text and delete it ]
With this Eclipse/Emacs, I cannot figure out the keystrokes for this? Can
anyone give me some assistance here. It is painful when working with large
files and trying to delete blocks without this.
Re: Emacs Select Multiple Lines [message #180352 is a reply to message #180344] Wed, 15 November 2006 16:35 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Scott wrote:
> hello,
> area of text and delete it ]
You don't need a special plug-in for that. Simply switch to the Emacs
key binding scheme and use 'Set Mark' command.
Dani
> Can anyone give me some assistance here. It is painful when working
> with large files and trying to delete blocks without this.
Re: Emacs Select Multiple Lines [message #180360 is a reply to message #180352] Wed, 15 November 2006 16:52 Go to previous messageGo to next message
This is real new to me. If you don't mind I could use a bit more
assistance.
1) Simply sitch to the emacs key binding scheme? How is this done?
Here is how I am working: Under Preferences->General->Editors->Keys, there
is a tab modify and it shows "scheme: Emacs"
Is this correct?
2) Where is the 'Set Mark' command located at?
Thanks much.
Scott
Re: Emacs Select Multiple Lines [message #180557 is a reply to message #180360] Thu, 16 November 2006 08:00 Go to previous message
> assistance.
> there is a tab modify and it shows "scheme: Emacs"
> Is this correct?
Yes.
It's in the 'Text Editing' category and the default shortcuts when using
the Emacs scheme are Ctrl+Space and Ctr+2. There's also a 'Clear Mark'
(Ctrl+G). The text between the set mark and the caret location are
treated as a selection when using copy and paste.
HTH
Dani
> Thanks much.
> Scott
Previous Topic:How to salvage important files from old installation
Next Topic:Cannot get CDT 3.1.1 to work under eclipse SDK 3.2.1
Current Time: Tue Apr 16 22:04:19 GMT 2024
Powered by FUDForum. Page generated in 0.14732 seconds
