Problem with GEF/EMF Workflow example under Linux [message #179638] |
Fri, 29 April 2005 06:56 |
Originally posted by: nathanoj.gmail.com
Hi guys,
Has anyone here had a problem with the Workflow example when run under the
Linux GTK environment? It seems it is not able to draw the model everytime I
close and then open a workflow file. The model objects was correctly
serialized but when trying to open it no figures are drawn in the editor...
Here is the steps I made:
1. I run the the two workflow plugins: the model and the editor in the
latest Eclipse 3.1 M6 under Linux
2. I created a workflow file and added a task object
3. I then saved and closed the file..
4. I opened the same file again and I can not see the task object I created
anymore but when I look at the workflow file using a wordpad, the task
object was correctly serialized there...
I have based a project I am owrking on in the workflow example and it is
also has the same behavior...
Can someone help me with this weird behaviour? Attached is the workflow
example I have modified to enable it to run on the latest Eclipse/GEF and
EMF versions...
Thanks a lot!
Jon
Attachment: workflow.zip
(Size: 589.29KB, Downloaded 187 times)
FUDForum. Page generated in 0.05871 seconds
