Terminating out of run leaves .exe file busy [message #179533] |
Sat, 11 November 2006 19:35 |
Originally posted by: jcobban.magma.ca
Whenever I prematurely terminate a C++ program that I am executing under
"run" the .exe file is left busy. This means:
1) I cannot rebuild the C++ program because I get the messages:
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin /bin/ld: cannot
open output file Ged2Html.exe: Device or resource busy
collect2: ld returned 1 exit status
make: *** [Ged2Html.exe] Error 1
make: Target `all' not remade because of errors.
2) I cannot even delete the .exe.
The only workaround I know for this is to shut down and restart Win XP.
Is there any easier way to get around this?
I am running: Version: 3.0.2, Build id: 200503110845
FUDForum. Page generated in 0.03412 seconds
