When I launch my Data View its not available [message #179355] |
Fri, 10 November 2006 07:01 |
Originally posted by: tstrike.geocities.com
To all:
I have my data source configured and connected to the database; however,
when I pull up my data view to configure my data sources I get "a data
view not available" error.
I also tried to use the cheat sheets only to get a java null error.
Did I forget to install something else?
I have itext 1.3 in the appropriate the plugin directory and I have my
JDBC drivers as needed.
Best Regards,
JT
Re: When I launch my Data View its not available [message #179406 is a reply to message #179355] |
Fri, 10 November 2006 14:16 |
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
JT Edwards wrote:
> To all:
> Best Regards,
> JT
It might help if you post the exception and stack trace from the error.
I assume that you're using the datatools. If this is the case, then this
question might get better answers if it is posted on eclipse.dtp.
Wayne
FUDForum. Page generated in 0.08919 seconds
