remove fields on "ContextMenuProvider" [message #178943] |
Sun, 24 April 2005 20:33  |
Originally posted by: J_ML.netcabo.pt
Hi guys.
Let's see if i can explain myselfe... I have a menu on my GEF editor, i've
already added some actions and all works fine. The problem is that the
eclipse platform insists on displaying some menu actions that i would like
to be hidden. Like submenus "Team" "Input methods" "replace with" "compare
with" bla bla bla...
how can i get those off my menu? it also adds "Runs as" "debug as"
"profile as" ..... I've already tried to remove the groups added by
default and leave the groups i use, like:
manager.remove("org.eclipse.gef.group.find");
manager.remove("org.eclipse.gef.group.print");
manager.remove("org.eclipse.gef.group.save");
manager.remove("org.eclipse.gef.group.copy");
manager.remove("org.eclipse.gef.group.edit");
since i'am using the Undo, Rest and View groups.
i would get a printscreen but it does not capture the menu on my linux
desktop.
Thanks.
Re: remove fields on "ContextMenuProvider" [message #178960 is a reply to message #178943] |
Mon, 25 April 2005 03:26   |
You should open bugs against the platform. If these menuitems are disabled
or not working, they shouldn't be polluting your editor.
It sounds like you are telling the workbench about your menumanager so that
you can support extensions. I'm not sure how those items get added after
that point.
""jos
Re: remove fields on "ContextMenuProvider" [message #179006 is a reply to message #178960] |
Mon, 25 April 2005 13:28   |
hi, thanks for trying to help, but i'am not sure i understand this two
lines:
<< You should open bugs against the platform. >>
<< It sounds like you are telling the workbench about your menumanager so
that
you can support extensions. >>
José
FUDForum. Page generated in 0.02060 seconds
