Home » Eclipse Projects » GEF » endless loop when moving figure outside of display area
endless loop when moving figure outside of display area [message #178817] |
Fri, 22 April 2005 17:16  |
Originally posted by: christian.sell.netcologne.de
I have a graphical editor developed on top of GEF 3.1M6. I just
discovered that when I slowly drag a figure outside of the displayed
editor area, at a certain point the app goes into an endless loop and
completely locks up. Prior to this, I see the scrollbar becoming very
small very fast, as if the figure was moving way beyond the display area.
I ran the app in the debugger and suspended it randomly. The main thread
seems to be looping around calls to revalidate() to different figures in
the GEF-internal hierarchy. Heres the stack:
Thread [main] (Suspended)
ArrayList.indexOf(Object) line: 220
ArrayList.contains(Object) line: 201
DeferredUpdateManager.addInvalidFigure(IFigure) line: 115
LightweightSystem$RootFigure(Figure).revalidate() line: 1351
FreeformViewport(Figure).revalidate() line: 1353
FreeformLayeredPane(Figure).revalidate() line: 1353
FreeformLayer(Figure).revalidate() line: 1353
ResizeHandle(Figure).revalidate() line: 1353
ResizeHandle(AbstractHandle).ancestorMoved(IFigure) line: 84
AncestorHelper.fireAncestorMoved(IFigure) line: 107
AncestorHelper.figureMoved(IFigure) line: 98
FreeformLayeredPane(Figure).fireFigureMoved() line: 461
FreeformLayeredPane(Figure).setBounds(Rectangle) line: 1403
FreeformHelper.setFreeformBounds(Rectangle) line: 86
FreeformLayeredPane.setFreeformBounds(Rectangle) line: 106
FreeformViewport.readjustScrollBars() line: 78
FreeformViewport(Viewport).validate() line: 364
LightweightSystem$RootFigure(Figure).validate() line: 1738
DeferredUpdateManager.validateFigures() line: 271
DeferredUpdateManager.performUpdate() line: 143
DeferredUpdateManager$UpdateRequest.run() line: 40
RunnableLock.run() line: 35
UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 118
Display.runAsyncMessages(boolean) line: 2755
Display.readAndDispatch() line: 2475
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 1570
Workbench.runUI() line: 1534
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line:
can anybody help me with debugging this? I tried to reproduce it with
other similar apps, but without success. It must be somewhere with mine,
but I am rather clueless at the moment.
thanks,
chris
Re: endless loop when moving figure outside of display area [message #178837 is a reply to message #178817] |
Fri, 22 April 2005 18:38   |
ok, never mind, i found the culprit. A simple equals() check in the move
command did the trick.
Christian Sell wrote:
> Hello,
> thanks,
> chris
rejoiced too early - still happens [message #178885 is a reply to message #178837] |
Sat, 23 April 2005 15:17   |
unfortunately, I was too optimistic. The problem still appears. When I
drag a figure across the border of the display area, the diagram srcolls
to the side very fast. As soon as I release the figure, the IDE locks up..
>> Hello,
>> thread seems to be looping around calls to revalidate() to different
>> figures in the GEF-internal hierarchy. Heres the stack:
>> mine, but I am rather clueless at the moment.
>> thanks,
>> chris
more details [message #178895 is a reply to message #178885] |
Sat, 23 April 2005 17:21   |
Hello
heres a few more findings, in the hope that someone will point me to the
problem:
- the phenomenon only seems to be happening when a figure is moved to a
negative x or y location, i.e. beyond the left or top border of the
diagram area.
- as soon as the mouse pointer touches a certain threshhold, the
movement of the viewport starts. This is the same on all borders (and
expected behavior), but with a negative location it becomes extremely
fast, the scrollbar size decreses very quickly.
- as soon as the (negative) location is set on the figure, the IDE locks up
- if I disable setting of the location (canExecute returns false for
negative locations), the move is undone automatically but takes place
rather slow, as if a movie was played backwards
chris
Re: more details [message #178921 is a reply to message #178895] |
Sun, 24 April 2005 16:25   |
You are probably mixing things that shouldn't be mixed. For example, if you
are using the Freeform root editpart, you must use freeformXxxx everywhere,
including hte layout manager.
Put a breakpoint in DeferredUpdateManager.addInvalidFigure once the infinite
loop has started.
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:d4e09k$2n6$1@news.eclipse.org...
> Hello
> problem:
> diagram area.
> - as soon as the mouse pointer touches a certain threshhold, the movement
> of the viewport starts. This is the same on all borders (and expected
> behavior), but with a negative location it becomes extremely fast, the
> up
> chris
Re: more details [message #178936 is a reply to message #178921] |
Sun, 24 April 2005 20:13  |
wow, I think that did it. I was using XYLayout instead of
FreeformLayout. Small cause large consequence.
thanks
chris
> loop has started.
>>Hello
>>problem:
>>diagram area.
>>up
>>chris
Current Time: Wed Feb 08 08:37:26 GMT 2023
Powered by FUDForum. Page generated in 0.02745 seconds
