Home » Eclipse Projects » GEF » Polygon Figure disappears when moved
Polygon Figure disappears when moved [message #178511] |
Wed, 20 April 2005 16:37  |
Originally posted by: jduley.mail.arc.nasa.gov
I have a GEF application that has nodes that I create from the palette.
One of the node figure types is a polygon (triangle). When I first
drag the polygon onto the canvas, it displays correctly. As soon as I
drag it to another location, it disappears. Any idea what is going on?
BTW, I have tried using both the org.eclipse.draw2d.Polygon and the
org.eclipse.draw2d.PolygonDecoration and the same thing happens with both.
Jason
Re: Polygon Figure disappears when moved [message #178541 is a reply to message #178527] |
Wed, 20 April 2005 17:44   |
Yes I am:
//begin refreshVisuals snippet
MyFig f = (MyFigure)getFigure();
Point location = f.getLocation();
MyDiagramPart parent = (MyDiagramPart) getParent();
Rectangle constraint = new Rectangle(location.x, location.y, -1, -1);
parent.setLayoutConstraint(this, f, constraint);
//end snippet
Pratik Shah wrote:
> You should use Polygon, not PolygonDecoration. Are you updating the
> constraint in refreshVisuals()?
> "Jason Duley" <jduley@mail.arc.nasa.gov> wrote in message
> news:d460hd$rcr$1@news.eclipse.org...
>>Hi,
>>Jason
Re: Polygon Figure disappears when moved [message #178549 is a reply to message #178541] |
Wed, 20 April 2005 17:51   |
Pratik Shah Messages: 1077 Registered: July 2009 |
When you say drag the polygon, you don't mean reparent it, right? Just look
at the figure before and after and see what has changed. That should give
you a clue.
Apparently, you're not just using Polygon, but subclassing it. What does
your Polygon subclass, MyFigure, do?
news:d464es$13o$1@news.eclipse.org...
> Yes I am:
> //end snippet
> >>Hi,
both.
> >>Jason
Re: Polygon Figure disappears when moved [message #178557 is a reply to message #178549] |
Wed, 20 April 2005 18:03   |
Pratik,
No, I am not reparenting it, simply moving it to a new location.
Apparantly, when I move the node and the triangle disappears, I can move
the node back to the original location and the trianlge is there again.
I guess what is happening is the node figure is moving but the
triangle it contains is not moving but staying at it's original
location. I have other nodes that contain rectangles and ellipses and
this is not occuring. Do I need to do something different given this is
a polygon? Also, I tried the Triangle class and it works fine. I would
like to discover what is happening with this polygon implementation
though. Thanks.
Jason
> you a clue.
>>Yes I am:
>>//end snippet
>>>>Hi,
> both.
>>>>Jason
Re: Polygon Figure disappears when moved [message #178565 is a reply to message #178511] |
Wed, 20 April 2005 20:01   |
You cannot use polygon as you would a normal figure. It is intended for use
with PolylineConnection.
You must call setPoints on a polygon. You cannot call setBounds(). Also, it
does not implement translate.
> One of the node figure types is a polygon (triangle). When I first drag
> the polygon onto the canvas, it displays correctly. As soon as I drag it
> to another location, it disappears. Any idea what is going on? BTW, I
> Jason
Re: Polygon Figure disappears when moved [message #178648 is a reply to message #178557] |
Thu, 21 April 2005 03:12  |
Rudolf Hornig Messages: 12 Registered: July 2009 |
Junior Member |
Polygon is different than the rest of the figures in a way that you
should NOT set its bounds. You have to translate each point in it's
point list to move it around. Bacause layout managers use also setBounds
they cannot move / layout a figure either.
If you are subclassing from Polygon you may do a little dirty trick and
override the setBounds method to translate all the polygon's points as
necessary...
Rudolf
Jason Duley wrote:
> Pratik,
> I guess what is happening is the node figure is moving but the triangle
> it contains is not moving but staying at it's original location. I have
> other nodes that contain rectangles and ellipses and this is not
> occuring. Do I need to do something different given this is a polygon?
> Also, I tried the Triangle class and it works fine. I would like to
> discover what is happening with this polygon implementation though.
> Thanks.
> Jason
>> Just look
>> give
>> you a clue.
>>> Yes I am:
>>> //end snippet
>>>>> Hi,
>>>>> palette.
>>>>> on?
>> both.
>>>>> Jason
Current Time: Wed Feb 08 08:26:49 GMT 2023
Powered by FUDForum. Page generated in 0.02403 seconds
