cant build [message #172066] |
Thu, 21 September 2006 21:10 |
Originally posted by: marceloazevedo.jr.gmail.com
Hi. There is something wrong here... and I'd like some help lease.
I followed all the steps to create a simple project
*file -> project -> standard make c++ project -> name: hello
then..
*right click on hello -> new file -> name main.c -> finish
code
#include <stdio.h>
void main()
printf("hello\n");
save and build and the console shows:
make -k clean all
MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
Incorrect command line argument: -k
Syntax: MAKE [options ...] target[s]
-B Builds all targets regardless of dependency dates
-Dsymbol[=string] Defines symbol [equal to string]
-Idirectory Names an include directory
-K Keeps (does not erase) temporary files created by
MAKE
-N Increases MAKE's compatibility with NMAKE
-Wfilename Writes MAKE to filename updating all non-string
options
-Usymbol Undefine symbol
-ffilename Uses filename as the MAKEFILE
-a Performs auto-dependency checks for include files
-c Caches auto-dependency information
-e Ignores redefinition of environment variable macros
-i Ignores errors returned by commands
-l+ Enables use of long command lines
-m Displays the date and time stamp of each file
-n Prints commands but does not do them
-p Displays all macro definitions and implicit rules
-q Returns zero if target is up-to-date and nonzero
if it is not (for use in batch files)
-r Ignores rules and macros defined in BUILTINS.MAK
-s Silent, does not print commands before doing them
-? or -h Prints this message
Options marked with '+' are on by default. To turn off a default
option follow it by a '-', for example: -a-
what can I do?? bellow the hello icon on the left there is just the main.c
with stdio.h and main bellow main.c
txs
Re: cant build [message #172136 is a reply to message #172066] |
Fri, 22 September 2006 09:10 |
Originally posted by: dmsubs.NOSPAM.consertum.com
I see you are using Borland make. CDT is expecting to use a GNU compatible make.
The options for GNU and Borland make are different. CDT is using the '-k' option
(to ignore errors) which (according to your listing below) equates to the
Borland '-i' option.
I don't know of a *simple* way of making this change (It is defined in the
plugin.xml file for the CDT Managed Build System).
I suggest you need to get yourself a copy of a GNU compatible make.
Derek
> then..
> code
> #include <stdio.h>
> void main()
> printf("hello\n");
> make -k clean all MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
> -K Keeps (does not erase) temporary files created by MAKE
> options
> main.c with stdio.h and main bellow main.c
> txs
FUDForum. Page generated in 0.03635 seconds
