Flakiness with Navigator and linked folders [message #171589] |
Tue, 19 September 2006 17:52 |
Originally posted by: jwlum.alum.mit.edu
I posted here back on July 13 ("Internal errors when Refreshing a linked
folder"; Message ID: e95rj8$4qj$1@utils.eclipse.org), but received no
reply, so I figured I'd try again with a more general inquiry.
Eclipse's Navigator view seems very flaky when I create a (General)
Project and then add several linked folders to that project. The two
linked filesystems are perhaps 2000 and 500 files, respectively, and I
periodically see the following two problems:
1. 'An internal error occurred during: "Refresh"' following a refresh
operation on the linked folder root or one of its subfolders.
2. Subfolders of the linked folder sticking around for a time and then
simply disappearing from the tree hierarchy
I've observed these problems with a number of different Eclipse versions
(all 3.x) on a number of different machines (all Windows). Does anyone
have any insight or advice on using the Navigator view effectively with
relatively large linked folders?
John
Re: Flakiness with Navigator and linked folders [message #171841 is a reply to message #171589] |
Wed, 20 September 2006 16:59 |
I can't offer any ideas to solve or workaround that problem, but I will
suggest that you file a bug report with detailed steps to reproduce it.
Bugzilla is the way to get the attention of the Eclipse developers about
potential bugs.
Hope this helps,
Eric
FUDForum. Page generated in 0.09203 seconds
