Home » Eclipse Projects » GEF » model change notification from commands
model change notification from commands [message #171404] |
Sat, 12 March 2005 16:03 |
Originally posted by: alnospammajor.noboxspamspoon.com
all the standard GEF samples show model change notifications being fired
from within the set-methods of the model itself.
however, it seems to me that there are benefits to be gained from having
change notifications be issued by commands (in the execute and undo
methods) rather than by the model.
the issue here is the lack of an obvious place to hook the listener into
the object to be monitored. at the time the command is to be executed,
it needs to figure out all the parts of the UI that need to be notified.
one approach would be to maintain a map of EditParts (for GEF viewers)
or other listeners (applicable to non GEF viewers as well) which are
indexed by model elements. so when the command executes, it figures out
which listeners need to be notified based on the model elements that are
changed. viewer activation and deactivation would have to do maintenance
on this map (instead of hooking into the model directly).
does anyone have any experience with this? is this a reasonable way to
proceed?
regards,
al
Re: model change notification from commands [message #171475 is a reply to message #171468] |
Sun, 13 March 2005 09:32 |
Pratik Shah wrote:
> "Al Major" <alnospammajor@noboxspamspoon.com> wrote in message
> news:d0v3tc$r7v$1@www.eclipse.org...
> Like what? I don't think this is a reasonable way to proceed.
batching notifications for compound commands for one (to minimize the
number of display refreshes). the fire from set-method is, in general,
quite fine grained.
regards,
al
Re: model change notification from commands [message #171478 is a reply to message #171404] |
Sun, 13 March 2005 09:37 |
i realized a hybrid approach is possible. hook the listeners into the
model as shown in current samples. but make the model's fire/notify
method public. call this fire/notify from within the command code
(instead of from the set-methods of the model code). this appears to
allow the desired flexibility without requiring much change to existing
GEF ways of doing things.
regards,
al
Re: model change notification from commands [message #171540 is a reply to message #171515] |
Mon, 14 March 2005 01:52 |
>>quite fine grained.
> The display refreshes just once when all the commands in the CompoundCommand
> have executed and all the notification has been fired.
is that so? that's clever! i'll go look at the code and see what's
going on.
there's a less concrete justification: in my app it seems like a
cleaner design. the model is used not only for graphical editing, but
also in a batch processing mode where there are no listeners. the
commands are only used for graphical editing. so it seemed "obvious" to
put the notifications in the command.
and it's parsimonious. all model changes in graphical editing are being
made through the commands anyway. and the commands have a coarser
grained picture of the model changes and so can minimize the number of
notifications. in that sense it seemed quite reasonable. but i recognize
that this may be a matter of personal taste.
and with the alternative design that i proposed in the other thread,
i.e. listeners in the model, but notification from the command, i can
use most of the standard GEF idiom for "hooking" / "unhooking". so the
initial cost of doing things this way is quite low.
do you see a problem with doing things this way? any concrete downside?
regards,
al
Re: model change notification from commands [message #171550 is a reply to message #171540] |
Mon, 14 March 2005 04:38 |
Pratik Shah Messages: 1077 Registered: July 2009 |
news:d12qq5$s07$1@www.eclipse.org...
> >>quite fine grained.
CompoundCommand
> going on.
You won't find it in GEF. It's in Draw2d. It uses a DeferredUpdateManager
that queues painting on the display thread, and hence first waits for
whatever's on that thread to finish executing.
I've always seen commands as part of the model. Manipulating the model, and
ignorant of the UI. That way they're only dependent on the model's
minimalistic interface (I say minimalistic because it won't be polluted by
methods like fireNotification()). This is one of the many reasons your
approach is a poor one.
I think what you want is something to wrap the actual model objects. That
something can provide the notifcation mechanism. Maybe it'll become your
view model and can store graphical information that your business model
doesn't really care about (location, size, etc.)
Everything's a trade-off in software design. The miniscule performance (and
increased complexity) that you're trading off the modifiability, cohesion
and reduced coupling (that our recommended approach presents) for is not
worth it.
> regards,
> al
Re: model change notification from commands [message #171557 is a reply to message #171540] |
Mon, 14 March 2005 05:29 |
>>> quite fine grained.
>> CompoundCommand
> going on.
> being made through the commands anyway. and the commands have a coarser
> regards,
> al
You would only be able to use your models from within the commands. If
one model tries to modify another, you will have an issue. Its more
flexible to have the models handle things that have to do with the
models like notificaiton of change. Besides, I may setLocaiton(0,0) and
my model may already be at 0,0,and thus wont fire an event. A command
would have harder time doing that.
CL
Re: model change notification from commands [message #171580 is a reply to message #171557] |
Mon, 14 March 2005 06:34 |
this is not an issue in my design.
hmm. that's worth thinking about. thanks.
regards,
al
Re: model change notification from commands [message #171588 is a reply to message #171550] |
Mon, 14 March 2005 06:47 |
>>going on.
thanks for the pointer. how much control does one have on when that
happens?
the commands in GEF are supposed to be relatively ignorant of the UI.
is that not so? at least the way that i'm using them they are. at some
point i imagine they're going into a platform commandstack, so i dont'
want any GEF dependencies if i can help it. i'm not advocating
otherwise. but the commands perform model interactions that are specific
to interactive access.
the way i'm advocating using commands is sort of view specific model
mutators. they can probably be viewed as part of the "view model" in
that sense.
> worth it.
hmm. we appear to have a difference of opinion. i see it as a decrease
in complexity, and a more reasonable separation of concerns. i guess
i'll find out as the complete implentation proceeds. if it turns out
that modifiability, cohesion and reduced coupling are sacrificed (which
they don't currently appear to me to be), i will, of course, change my mind.
incidentally, i've been browsing through some of the larger codebases
that use GEF. the BIRT project has a model in which the "transactions"
are firing off the notifications. they're not GEF "commands" per se, but
the usage is similar to the way that i'm using commands. if you have the
time to look at it i'd appreciate your comments and any critique you may
have about that approach.
are there any other specific objections that you have to this approach?
btw, i appreciate your effort in answering what are somewhat "big
picture" questions.
regards,
al
Re: model change notification from commands [message #171674 is a reply to message #171588] |
Mon, 14 March 2005 17:34 |
GEF will move to the platform's operation framework too (although not for
the 3.1 release).
Here's a quick run-down of some problems I find with your approach --
- CompoundCommand will have to figure out whom to notify -- ask all the
child Commands -- and do some batch notification. Hence, added
responsibility for commands and increased complexity
- duplication of code in several places - if more than one command calls
setXYZ() on a model, they're responsible for notifying its listeners as
well; and if somebody else invokes those methods (such as property sources
for the property sheet), they have to do the same
- littered model interface
- violating encapsulation by providing access to what should be internal to
the model -- the listeners (reduced cohesion and increased coupling stem
from this)
This is my last post on this topic. I hope you'll make the right choice.
news:d13c2f$tvk$1@www.eclipse.org...
> >>going on.
> happens?
and
by
That
your
> that sense.
(and
cohesion
> > worth it.
mind.
> picture" questions.
> regards,
> al
Re: model change notification from commands [message #171714 is a reply to message #171580] |
Mon, 14 March 2005 18:27 |
>> If one model tries to modify another, you will have an issue. Its more
I understand. You will find lots of these types of things in GEF. But
GEF is a library and has to please a lot of different people so its more
general. Sometimes this is less efficient for one application or
another. But it gets the job done in the end. And of course sometimes
it needs to be changed to need the needs of a different application no
one thought about yet.
>> and my model may already be at 0,0,and thus wont fire an event. A
>> command would have harder time doing that.
> regards,
> al
Re: model change notification from commands [message #171807 is a reply to message #171674] |
Tue, 15 March 2005 06:46 |
thank you for your comments. i'll definitely keep these in mind.
looking back over my previous posts, i realize i've set the wrong tone,
completely unintentionally. it sounds like i disagree with the
notification design decisions in the GEF samples.
i don't. i think the decisions make complete sense in the context of a
model that has been designed from the ground up with GEF in mind.
i'm in a different situation, with an existing model into which
graphical editing is being retrofitted. i want to make minimal changes
to the existing code base. in _this_ context, making the changes
initially in the commands results in the minimum perturbation of
existing code. it is parsimonious.
i apologize for not making this context more clear.
indeed, it's quite possible that eventually the command code will be
refactored into a "view model" as you suggest. but that's for a later
stage in the game.
overall, i think GEF is an excellent library with good design decisions.
the samples are very comprehensive in illustrating how to write GEF code.
it's a measure of how _good_ (successful) the GEF design is, that it's
now being used on pre-existing (non GEF) models. in this process it is
inevitable that people will come up with idioms and design variations
that make sense in their particular context. this is not in itself a bad
thing. nor does it invalidate the decisions made in the sample code.
it's just an acknowledgement of the reality that there is no such thing
as a one size fits all design.
and comments on the cons of particular designs from knowledgeable users
are very valuable. thus i truly appreciate your and CL's feedback.
sorry for going meta-topic, but i think these are points worth making.
and i do want to make clear that i think quite highly of the GEF samples
in particular and the library in general. and of course of the guys that
wrote that code ;-).
regards,
al
> the 3.1 release).
> from this)
>>>>going on.
>>happens?
> and
> by
> That
> your
>>that sense.
> (and
> cohesion
>>>worth it.
> mind.
>>picture" questions.
>>regards,
>>al
Re: model change notification from commands [message #171847 is a reply to message #171807] |
Tue, 15 March 2005 14:25 |
> stage in the game.
If this is the case, then your best bet is to wrap your existing models
with a class that handles firing the events. Then you won't have to
refactor you commands when eventually the models handle notification
natively.
Its not so bad an idea that each tool that would use your models would
need such a wrapper/adapter class. In this way you can let gEF stick to
the GEF architecture, and your models stick to their architecture. Let
the adapter bridge the gap.
there should be no such thing as a 'GEF' model. As I said in the other
thread, my models have no knowledge of anything but pure java classes,
no eclipse/swt/gef classes whatsoever. And My models were preexisting.
There was one change i made to my models to satisfy GEF, but you are
not having a similar issue at this point.
I think the wrapper is your best bet. You want to stay as close to the
GEF architecture as you can so you can take advantage of new GEF
features when they are added. I will soon be adding support for snaps
and rulers to my editors soon. I'm hoping for an easy transition as I
have stuck closely to the Gef model.
CL
Re: model change notification from commands [message #171863 is a reply to message #171674] |
Tue, 15 March 2005 16:06 |
> the 3.1 release).
This actually needs to be weighed against the amount of API breakage that
would occur. We still need to investigate this since the platform API is
not finalized.
Re: model change notification from commands [message #171871 is a reply to message #171404] |
Tue, 15 March 2005 16:11 |
Batching model changes is possible. The batching would be done by your
model implementation or a mediator.
Using a single "domain" notifier is also doable. The EditPartRegistry
provides the necessary model->part mapping to dispatch the model changes.
Turning off non-graphical UI updating (such as TreeItem construction) is
possible to. Use SWT's setRedraw(false), and hook into the new command
stack events which tell you whenever something is starting to happen and
when it is completed.
Re: model change notification from commands [message #172048 is a reply to message #171847] |
Wed, 16 March 2005 03:26 |
> natively.
are you suggesting that for each class in my model i have a delegating
class with identical interface that delegates every single method to the
main class? and a few of the methods fire notifications as well?
basically create a delegating mirror of the entire model hierarchy?
Re: model change notification from commands [message #172100 is a reply to message #172048] |
Wed, 16 March 2005 14:04 |
>> models with a class that handles firing the events. Then you won't
>> have to refactor you commands when eventually the models handle
>> notification natively.
>> to the GEF architecture, and your models stick to their architecture.
>> Let the adapter bridge the gap.
> delegating class with identical interface that delegates every single
> method to the main class? and a few of the methods fire notifications as
> well? basically create a delegating mirror of the entire model hierarchy?
Yes, but a wrapper should be sufficient. You shouldn't need a proper
delegate, since the events are firing by the wrapper and not the wrapee.
Allows all your changes to be within a single class, instead of changing
GEF a bit and changing your models a bit.
CL
Re: model change notification from commands [message #172210 is a reply to message #172100] |
Thu, 17 March 2005 00:35 |
i'm still not sure i understand. if i have a model hierarchy
class A {
public void a ()
class B extends A {
public void b ()
class C extends A {
public void c ()
the wrapper is
class Wrapper {
public void modifyA (A obj) {
obj.a ();
obj.fire ();
public void modifyB (B obj) {
obj.b ();
obj.fire ();
public void modifyC (C obj) {
obj.c ();
obj.fire ();
is this what you mean? if not, could you provide some pseudocode to clarify?
regards,
al
Re: model change notification from commands [message #172218 is a reply to message #171871] |
Thu, 17 March 2005 00:36 |
thanks!
Current Time: Fri Apr 19 04:50:46 GMT 2024
Powered by FUDForum. Page generated in 0.03069 seconds
