Passwords for extracting zip file [message #170212] |
Sun, 10 September 2006 01:02 |
Originally posted by: fjbarbe.aol.com
This is my firs time using eclipse. I downloaded the zip file but after
the plugin directory is extracted it requests passwords for the rest of
the files.
How do I obtain this password?
Jerome Barber
fjbarbe@aol.com
Re: Passwords for extracting zip file [message #170223 is a reply to message #170212] |
Sun, 10 September 2006 04:19 |
Originally posted by: jefmyers.us.ibm.com
Jerome,
The eclipse zip files from www.eclipse.org do not have passwords on
them. If you encounter this problem it probably means your zip client is
not functioning properly. Which one are you using? You might want to
try using 7-Zip instead: http://www.7-zip.org/
Hope this helps,
- Jeff
> the files.
> Jerome Barber
> fjbarbe@aol.com
Re: Passwords for extracting zip file [message #215935 is a reply to message #170223] |
Fri, 15 June 2007 03:57 |
Originally posted by: fritzr_gc.yahoo.com
Thank you Jeff
Just ran into the same problem
Win XP SP2 ... using the built in UnZip
Unpacked to the download folder
Zip file is in long dir tree and requested a password for a single file.
7-Zip failed to unpack 14 files to same target dir
7-Zip unpacked without error to C:\Eclipse SDK\
Fritz
Jeff Myers wrote:
> Jerome,
> Hope this helps,
> - Jeff
>> after the plugin directory is extracted it requests passwords for the
>> rest of the files.
>> Thanks,
>> Jerome Barber
>> fjbarbe@aol.com
FUDForum. Page generated in 0.08159 seconds
