sharing workspaces [message #169942] |
Thu, 07 September 2006 15:11 |
Originally posted by: chadmichaeldavis.gmail.com
Is it possible to have a workspace, on a network for instance, that
multiple developers can use?
Re: sharing workspaces [message #169988 is a reply to message #169942] |
Thu, 07 September 2006 21:22 |
In theory, it's possible to some extent. Only one user could be using the
workspace at a time and each developer workstation would likely need to
have the same directory structure. However, this would definitly not be a
recomended approach.
Is there a specific reason that you want to share a workspace? The
prefered method would be to share the projects in the workspace instead of
the workspace itself.
Re: sharing workspaces [message #170008 is a reply to message #169988] |
Fri, 08 September 2006 02:17 |
> the workspace at a time and each developer workstation would likely need
> to have the same directory structure. However, this would definitly not
> be a recomended approach.
> of the workspace itself.
How does sharing a project work? Can two people have it open
simultaneously?
FUDForum. Page generated in 0.08695 seconds
