Eclipse Error: "Queueing viewer updates" [message #169502] |
Tue, 05 September 2006 12:47 |
Originally posted by: md.plusw.de
after using Eclipse 3.1 on FreeBSD since it's been released, I recently
switched to Ubuntu and Eclipse 3.2 with following plugins (all up-to-date):
- Aptana
- E-P-I-C
- Subclipse
- TeXlipse
All worked fine until yesterday. Since then, I get a message containing
"Error" sometimes. Not more. I think more often when I switch
applications (e.g. Eclipse -> Thunderbird) or the editor tabs, but I'm
not sure. Sometimes I also get a window like you can see on this image:
http://www.plusw.de/images/errors.jpg
I cannot find anything about this in ~/workspace/.metadata/.log.
Does someone has an idea what the cause of this could be?
Matt
Re: Eclipse Error: "Queueing viewer updates" [message #169518 is a reply to message #169502] |
Tue, 05 September 2006 13:05 |
Originally posted by: joensson.gmail.com
Matthias Dietrich <md@plusw.de> wrote in
news:edjrlc$jsp$1@utils.eclipse.org:
> recently switched to Ubuntu and Eclipse 3.2 with following plugins
> (all up-to-date):
> - Aptana
> - E-P-I-C
> - Subclipse
> - TeXlipse
> containing "Error" sometimes. Not more. I think more often when I
> switch applications (e.g. Eclipse -> Thunderbird) or the editor tabs,
> but I'm not sure. Sometimes I also get a window like you can see on
> this image:
Have you tried running eclipse with -consolelog -debug -clean parameters ?
Does it reveal anything new compared to your log?
Sorry does not have any suggestion as to what the problem could be.
Flemming
Re: Eclipse Error: "Queueing viewer updates" [message #170649 is a reply to message #169518] |
Tue, 12 September 2006 23:49 |
Originally posted by: rrodrigu.enlacenet.com.mx
Well
Ubuntu use its own Java based on GNU (Gcj), and I had the same problem.
I solved it just getting java from Sun and changing the access of (Gcj)
/usr/bin/java to Java of Sun Microsystems.
Greetings.
Roberto R.
Re: Eclipse Error: "Queueing viewer updates" [message #170656 is a reply to message #169518] |
Tue, 12 September 2006 23:51 |
>> (all up-to-date):
>> - Aptana
>> - E-P-I-C
>> - Subclipse
>> - TeXlipse
>> this image:
> Cheers,
> FlemmingWell
Greetings.
Roberto R.
FUDForum. Page generated in 0.09940 seconds
