New Class Wizard [message #169485] |
Tue, 05 September 2006 11:56 |
Originally posted by: francuesta.gmail.com
Hello, IŽm a new Eclipse user and IŽm developping a plug-in. I need know
the name of the classes that implements the wizard "New Class". I want do
something similar and it would be important for me.
Thank you very much!!!
Re: New Class Wizard [message #169546 is a reply to message #169485] |
Tue, 05 September 2006 13:43 |
Originally posted by: joensson.gmail.com
francuesta@gmail.com (Fran) wrote in
news:2579e0671b04790017fddda782216bf2$1@www.eclipse.org:
> Hello, I´m a new Eclipse user and I´m developping a plug-in. I need
> know the name of the classes that implements the wizard "New Class". I
> want do something similar and it would be important for me.
NewClassCreationWizard and NewClassWizardPage which can be found in
org\eclipse\jdt\internal\ui\wizards\
When you download eclipse sdk you also get the src. In your eclipse plugins
folder you must go into org.eclipse.jdt.source_3.2.0.v20060609m-F7snq1fxia-
Z4XP. There you will find a src folder. Inside the src folder you will find
a folder named org.eclipse.jdt.ui_3.2.0.v20060605-1400 and inside that
folder you will find the src.zip containing the source for the two files I
mentioned
I highly recommend TotalCommander for searching through the eclipse source
in the plugins folder since the source code is scattered over many src.zip
files. All it takes is hit Alt+F7, write the classname (or interface name
if that is all you know), and put a check in "Search archives", finally
click search and then you get a nice list.
Enjoy
/flemming
FUDForum. Page generated in 0.07708 seconds
