Source Dir Structure for Common Packages [message #168685] |
Thu, 31 August 2006 14:56 |
Originally posted by: steve.kincer.org
It seems that out of the box, eclipse expects you to put your souce in a dir
under the project folder. So, if my proj is called MyProj and my pkg is
com.mycompany.mypkg, the dir would be:
MyWorkspace\MyProj\com\mycompany\mypkg
I like to use certain common packages in a many projects that I do, so this
seems like a problem. For example, if I have a package called
com.mycompany.utils, I want to be able to import that in any other source
files as
import com.mycompany.utils.*;
I feel like I must be missing something in terms of how others structure
their development environment. It seems like everyone would want the source
root to be the same directory for every project they work on, and then have
the source for various projects/packages all have the same starting point.
How do others structure their source dirs when you have packages that you
use in many different projects?
Thanks.
Steve
Re: Source Dir Structure for Common Packages [message #169155 is a reply to message #168685] |
Mon, 04 September 2006 03:28 |
> files as
Two reasonable options that I see:
1: (most preferable) Put the common code into its own project (eg,
called Common) and then have other projects depend on that one when they
need its classes.
2: Any project can define however many source root folders as it wants,
and they don't have to be right below the project root. So you can copy
your common code into the other project(s) in a different source
location. Edit your project's properties and select the Java Build Path
section to see the Source locations tab.
I, personally, use the first approach; furthermore, I always have a
"source" directory in my projects (and sometimes a "java" directory
under that) where my package name structure starts. Like this:
MyProject/
build/
<this is my build output location>
lib/
<compile-time JAR files live here>
source/
java/
<package structure starts here,
<with .java files placed appropriately>
web/
<if needed>
someOtherKindOfSource/
<if needed>
Hope this helps,
Eric
FUDForum. Page generated in 0.05612 seconds
