Home » Eclipse Projects » GEF » showing properties for a list of items
showing properties for a list of items [message #168476] Wed, 16 February 2005 07:20 Go to next message
Originally posted by: alan.battersby.ntu.ac.uk
I am new to gef and still on a steep learning curve and also this question
is probably not gef specific please forgive my ignorance.
I have a Declaration class that contains a list of variable declarations.I
have also created a Variable class containing name,type and initialvalue
that implements the IPropertySource interface. Displaying one variable
defined alone, is not a problem.
When the DeclarationPart is selected I want the list off all variables
declared to appear in the properties window. One variable per line showing
name,type and initial value all to be editable. I assume that I must
create a DeclarationPropertySource class that iterates through the list but
am not sure how to start. I looked at the examples for flow, shapes and
logic but was unable to see anything similar to what I require.
Firstly is this possible? If so how do I go about it ? Is there something
in the examples above that I missed?
Alan
Re: showing properties for a list of items [message #168532 is a reply to message #168476] Wed, 16 February 2005 11:14 Go to previous messageGo to next message
> Thanks
> Alan
yes its possible. you just return an array of property descriptors. I
learned how to do it from the examples, so its in there. If I can, ill
post some example code.
CL
Re: showing properties for a list of items [message #168548 is a reply to message #168532] Wed, 16 February 2005 12:04 Go to previous messageGo to next message
>> question
>> declarations.I
>> showing
>> list but
>> Thanks
>> Alan
> CL
I would appreciate an example. I have looked at examples again but
cannot see any item that when selected show a list of items and
properties viz
Item 1
Prop 1 value 1
Prop 2 value
Item 2
Prop 1 value
Prop 2 value
Item 3
etc
So any code example would be greatly appreciated.
Alan
Re: showing properties for a list of items [message #168571 is a reply to message #168548] Wed, 16 February 2005 15:30 Go to previous message
>>> question
>>> declarations.I
>>> showing
>>> list but
>>> something
>>> Thanks
>>> Alan
>> I learned how to do it from the examples, so its in there. If I can,
>> ill post some example code.
>> CL
> properties viz
> Item 1
> Prop 1 value 1
> Prop 2 value
> Item 2
> Prop 1 value
> Prop 2 value
> Item 3
> etc
> Alan
One property source can return another property source as its value
instead of returning an int for instance. that property source can have
an array of descriptors, and a corresponding value for each one.
public Object getPropertyValue(Object id){
if(MyProperty.equals(id){
return new InteratingPropertySource(mystuff);
else return super.get....
class IteratingPropertySource{
public IPropertyDescriptor [] getPropertyDescritpros(){
for(int x=0;x < props.length;x++){
SubPropDescrip pd = new SubPropDescrip("Prop"+x,"value");
SubPropDescrip sps[x] = pd;
return sps;
for(int x=0;x<props.length;x++){
if(id.equals("Prop"+x)){
return new ValueSource(props[x]);
return null;
ValueSource is a simple source with a prop and a value.
if that does not help any send me an email and ill send u some files as
my email is on linux but my code is on windows mainly...
CL
Previous Topic:SWT widgets in Figures
Next Topic:Cancel a time consuming paint operation
Current Time: Sat Nov 08 14:56:39 EST 2025
Powered by FUDForum. Page generated in 0.03879 seconds
