Home » Newcomers » Newcomers » code assist not working in 3.2
code assist not working in 3.2 [message #167952] |
Mon, 28 August 2006 23:34 |
Originally posted by: jctown.nb.sympatico.ca
Is there anything I need to do besides:
Window, Preferences, Java, Editor, Content Assist
Enable auto activation (bottom of page)
Delay 200, Trigger should be a dot.
to make code assist work? If I type System.out. I would expect Eclipse
to pop up a list of options, but nothing happens. Even when I hit
CTRL+Space nothing. I'm using Eclipse 3.2 on a Windows XP Home PC on
a desktop and laptop. I also use the BEA Workshop version on my
Desktop... none of them have the expected behavior.
Re: code assist not working in 3.2 [message #168536 is a reply to message #168055] |
Thu, 31 August 2006 00:17 |
Daniel Megert wrote:
> JT wrote:
>> CTRL+Space nothing.
> Make sure the file you're editing is
> - in a Java project
> - the file is on the build path
> - you are editing the file with the Java editor
> Dani
Yes it is a Java project. I use the Java Perspective. The reason I am
curious is that when I was using 3.1, I had the code completion without
doing anything and now it's still there but I can't make it happen.
Re: code assist not working in 3.2 [message #168578 is a reply to message #168536] |
Thu, 31 August 2006 03:08 |
>> - in a Java project
>> Dani
You confirm that it is a Java project, but did not confirm the other two
points that Dani asked: is the file your editing included on the source
path, and is it opening in the Java editor.
If you don't understand those questions, just ask.
Hope this helps,
Eric
Re: code assist not working in 3.2 [message #168896 is a reply to message #168578] |
Thu, 31 August 2006 21:01 |
>>> - in a Java project
>>> Dani
> Hope this helps,
> Eric
Isn't is safe to assume that if I am using the Java Perspective then I
am using "the Java editor". If not, then since my code errors are
marked I would say that I am using the Java editor. Furthermore, I
just checked and the entire package is on the build path.
Re: code assist not working in 3.2 [message #169000 is a reply to message #168930] |
Fri, 01 September 2006 22:02 |
> JT wrote:
>>>>> - in a Java project
>>>>> Dani
>>> Hope this helps,
>>> Eric
> No. If a plug-in has been installed that sets itself as default for
> *.java files or Java content type then that editor will be taken no
> matter which perspective you're in.
> Might be - another editor could do this as well.
>> Furthermore, I
> Is there anything in .log? Could you strip down your workspace and
> attach it to a bug report?
> Dani
Is there a way to find this out by reading the Eclipse help? I'd rather
figure out how to strip my work space down without bothering anyone here.
Re: code assist not working in 3.2 [message #170298 is a reply to message #167952] |
Mon, 11 September 2006 08:02 |
Originally posted by: tom_eicher.ch.ibm.com
JT, have you used Mylar before? In that case, please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=140416
-t
JT wrote:
Current Time: Thu Apr 25 16:12:22 GMT 2024
Powered by FUDForum. Page generated in 0.05432 seconds
