| EMF enum property editor [message #167242] |
Sun, 06 February 2005 18:41  |
I am trying to set up my properties view for the enums in my EMF objects
using an IPropertySource similar to the Workflow example in the RedBook.
I have managed to create a ComboBoxPropertyDescriptor with the correct
string values based on the EEnum ELiterals collection but converting
between the index wanted by descriptor and the value of the feature is
rather awkward. Is there a straightforward way to do this or do people
create their own PropertyDescriptor that handles the underlying data
type better?
Barry
| Re: EMF enum property editor [message #167445 is a reply to message #167391] |
Tue, 08 February 2005 11:44   |
"Barry Lay" <blay@laysercomputing.com> escreveu na mensagem
news:cu9k5o$e9f$1@www.eclipse.org...
> Randy Hudson wrote:
>> Displaying an EMF object in the property sheet has nothing to do with
>> GEF.
> Ah, but it does. If you follow the "redbook" example and use
> GEFPlugin.createUndoablePropertySheetEntry(getCommandStack() ) and set that
> as the rootEntry for the property sheet page then things don't work
> according to the PlugIn Guide.
Again, you are using "EMF" to mean "EMF Edit". That's like using "Draw2d" to
refer to "GEF". They are different layers in the cake. I would prefer to
implement the PropertySource myself using my own adapter.
> Following the guide and the EMF editor example, setting the
> PropertySourceProvider on the PropertySheetPage to an appropriate content
> adapter should allow the EMF item provider to deliver PropertyDescriptors
> for the Property view. It doesn't work because the GEF
> UndoablePropertySheetEntry extends an internal GEF version of
> PropertySheetEntry which is not recognized by the
> setPropertySourceProvider method in PropertySheetPage. The latter
> silently does nothing which provides a debugging challenge.
So open a bug against Platform/UI. They should not be casting to their
specific implementation.
> In my opinion it is a poor design choice to advertise that setRootEntry on
> the Eclipse PropertySheetPage takes an IPropertySheetEntry but in fact
> requires a bonafide PropertySheetEntry to function properly. It is also a
> poor design choice on the GEF side to copy and modify the text of an
> existing class (PropertySheetEntry) into an internal package without even
> changing the name. You have to look at the imports to figure out why it
> doesn't work.
I'd say that keeping the same name was successful in identifying it as a
copy ;-). We already had enough trouble naming the undoable version. We plan
on subclassing:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=39243
> Going past the structural nuances and calling setPropertySourceProvider on
> the UndoablePropertySheetEntry still doesn't work because the EMF
> AdapterFactoryContentProvider expects to be dealing with model objects,
So have your editor send out the model objects as the ISelection instead of
EditParts. Mediate between the EditPartViewer and the selectionservice.
> not with GEF EditParts. In this case I suspect that the EMF provider
> should respect the IAdapter aspect of the EditPart and get the job done.
> This is not a simple "GEF is at fault"/"EMF is at fault" decision. There
> is a problem with the way these packages cooperate within the Eclipse
> framework, and I think that some curious design decisions are making it
> difficult for the less experienced of us to figure out what we are
> supposed to do. I am reminded of a battle I had many years ago with the
> ISPF and GDDM guys within IBM on why those two products just couldn't get
> along. At least we have the source code (for Eclipse) nowadays so that we
> can figure it out.
>>>I have decided to see if I can use the EMF generated providers to do the
>>>properties.
>> I would not design my application that way. It's straightforward to
>> write a propertysource implementation yourself. It is nothing but a big
>> switch statement.
> I haven't seen any convenient mechanisms to properly handle an EEnum,
> which was the basis for the original question. I can take apart the EMF
> ItemPropertyDescriptor to see how it does it, but why should I be
> essentially copying functionality from an existing set of code? Why can't
> I just use the provider that the EMF generates for me automatically?
Because writing a switch statement is really easy, and you don't encounter
all of the problems you described above, including the mangling of undo/redo
with nested properties or multiple selection.
| Re: EMF enum property editor [message #167468 is a reply to message #167391] |
Tue, 08 February 2005 13:15   |
"Barry Lay" <blay@laysercomputing.com> wrote in message
GEF.
> that as the rootEntry for the property sheet page then things don't work
> content adapter should allow the EMF item provider to deliver
> PropertyDescriptors for the Property view. It doesn't work because the
> GEF UndoablePropertySheetEntry extends an internal GEF version of
The EDiagram example uses the EMF-generated providers for properties. I
spent some time trying to sort out how things would work together (esp. the
undo/redo), so others could do it relatively easily. Look at
EDiagramEditor#getAdapter().
> on the Eclipse PropertySheetPage takes an IPropertySheetEntry but in
> fact requires a bonafide PropertySheetEntry to function properly. It is
> also a poor design choice on the GEF side to copy and modify the text of
> an existing class (PropertySheetEntry) into an internal package without
> even changing the name. You have to look at the imports to figure out
> why it doesn't work.
> on the UndoablePropertySheetEntry still doesn't work because the EMF
> There is a problem with the way these packages cooperate within the
> Eclipse framework, and I think that some curious design decisions are
> making it difficult for the less experienced of us to figure out what we
> are supposed to do. I am reminded of a battle I had many years ago with
> the ISPF and GDDM guys within IBM on why those two products just
> couldn't get along. At least we have the source code (for Eclipse)
> nowadays so that we can figure it out.
> >>properties.
write a
> > propertysource implementation yourself. It is nothing but a big switch
> > statement.
> can't I just use the provider that the EMF generates for me automatically?
> > There is a redbook on this subject.
> The one I have been looking at is "Eclipse Development using the
> Graphical Editing Framework and the Eclipse Modeling Framework",
> SG24-6302. I see your name in the contributions (or someone whose name
> is spelled the same as yours).
> I appreciate your help. i have no axe to grind regarding the design of
> any of the products I have been dealing with; I am just trying to get my
> program to work.
> Barry
| Re: EMF enum property editor [message #167650 is a reply to message #167474] |
Wed, 09 February 2005 19:01   |
Yes, it's built on the 3.1 code-base. The latter, however, was an actual
problem (I had unreleased changes in my workspace). Synch up with the
repository again. As for the ShortestPathConnectionRouter, you can either
just replace it with some other router in the code, or you'll have to move
to the 3.1 code-base.
news:cubj4l$bo9$1@www.eclipse.org...
the
> Ok, I am going through it now. Incidentally, I get compile errors for
> this project, for things like ShortestPathConnectionRouter not resolved
> and cannot invoke abstract method initCellEditor on DirectEditManager.
> Is this example based on a newer version of Draw2D and GEF than the
> current release? I am running Draw2D and GEF 3.0.1.
> Barry
| Re: EMF enum property editor [message #167879 is a reply to message #167851] |
Fri, 11 February 2005 13:49  |
Pratik Shah wrote:
> Now when you disabled the ShorestPathRouter or now when you moved to the 3.1
> code-base? EMF version should be 3.0.1, and you should have the
> org.eclipse.emf.ecore plug-in imported in your workspace.
It happened when I replaced the project from the repository. I ended up
deleting everything and reloading from CVS. That seems to have fixed
the problem.
Thanks.
FUDForum. Page generated in 0.06704 seconds
