Home » Archived » IAM (Eclipse Integration for Apache Maven) » Maven Core artifacts
Maven Core artifacts [message #15769] Thu, 13 November 2008 03:39 Go to next message
Is there a Maven repository with the 2.1 artifacts in it that are used
in Q4E? I can't see anything on Maven central or on the Apache
snapshots. So what is the status of 2.1? Will IAM be switching to
Maven 3.0 (or has it already)?
Re: Maven Core artifacts [message #15879 is a reply to message #15769] Thu, 13 November 2008 11:52 Go to previous messageGo to next message
There is a repository at:
http://q4e.googlecode.com/svn/repository/releases
There are also "frozen" versions of maven source code:
http://q4e.googlecode.com/svn/vendor/maven/current/
Development of IAM is based on a snapshot of the 3.0 (although updates are
expected, as maven 3.0 gets more stable).
Re: Maven Core artifacts [message #15897 is a reply to message #15879] Thu, 13 November 2008 12:20 Go to previous messageGo to next message
Thanks. I think you misunderstood (or I did). I can see Maven
artifacts in that repo, but nothing under org/apache/maven. Where are
the Maven artifacts pulled from? I would like to get hold of the ones
Q4E is using as well as the IAM dependencies.
Re: Maven Core artifacts [message #15915 is a reply to message #15897] Fri, 14 November 2008 23:08 Go to previous messageGo to next message
Originally posted by: carlos.carlossanchez.eu
The current version 2.1.0.659801b is generated by checking out the
revision 659801 from
https://svn.apache.org/repos/asf/maven/components/trunk
https://svn.apache.org/repos/asf/maven/artifact/trunk
do a
mvn clean install
and then do "mvn -o clean package" from
https://q4e.googlecode.com/svn/trunk/plugins/maven/embedder
The java sources used are in
https://q4e.googlecode.com/svn/trunk/plugins/maven/embedder/ sources
the jars are in
https://q4e.googlecode.com/svn/trunk/plugins/maven/embedder/ lib
Now, this is a problem and I tried to create a vendor branch as Abel
mentioned. We import maven sources into
https://q4e.googlecode.com/svn/vendor and then customize them in
https://q4e.googlecode.com/svn/trunk/thirdparty
But the 3 or so revisions of Maven that I tried were a bit buggy so I
finally didn't update the version used by Q4E. We can do that when the
IAM code is a stable in the Eclipse foundation. Hopefully by that time
too we'll have a 3.0-alpha release of the embedder.
Please don't hesitate to ask any questions, I know it's a bit cumbersome
to build.
Also you can download the command line version that matches the one used
by Q4E at http://code.google.com/p/q4e/downloads/list
Re: Maven Core artifacts [message #15933 is a reply to message #15915] Sat, 15 November 2008 03:38 Go to previous messageGo to next message
> the jars are in
Thanks for the detailed instructions. Any reason you can't just put the
jar artifacts (with sourecs) in the Maven repository at
http://q4e.googlecode.com/svn/repository/releases (or similar)?
Re: Maven Core artifacts [message #15951 is a reply to message #15933] Sat, 15 November 2008 13:17 Go to previous messageGo to next message
if you want we can do that. It wasn't ever needed as the embedder plugin
has both of them and can be available through eclipse
>> the jars are in
Re: Maven Core artifacts [message #15966 is a reply to message #15951] Sun, 16 November 2008 04:40 Go to previous messageGo to next message
Sorry, I'm a PDE dunce, but I know how to use Maven. Therefore it's
easier for me to use a Maven artifact than an embedded jar in an Eclipse
plugin. If you can tell me how to add the jar (and sources) to the
classpath in an Eclipse project, maybe that's all I need. If that
involves using PDE it is probably easier for you to just publish the
Maven artifacts.
In case your're wondering why I ask: right now, I just need to check
some assumptions with version ranges. But then this isn't the first
time I've thought that I needed to see what Q4E was doing, and being
able to see the source code is much more efficient than thrashing around
with other information sources.
Dave.
Re: Maven Core artifacts [message #15982 is a reply to message #15933] Tue, 18 November 2008 16:29 Go to previous message
>> the jars are in
I had updated the vendor branch
and pushing currently the jars and sources to our repo at
https://q4e.googlecode.com/svn/repository/releases
Re: Maven Core artifacts [message #568040 is a reply to message #15769] Thu, 13 November 2008 11:52 Go to previous message
Re: Maven Core artifacts [message #568071 is a reply to message #15879] Thu, 13 November 2008 12:20 Go to previous message
Re: Maven Core artifacts [message #568112 is a reply to message #15897] Fri, 14 November 2008 23:08 Go to previous message
do a
mvn clean install
the jars are in
to build.
Re: Maven Core artifacts [message #568142 is a reply to message #15915] Sat, 15 November 2008 03:38 Go to previous message
> the jars are in
Re: Maven Core artifacts [message #568170 is a reply to message #15933] Sat, 15 November 2008 13:17 Go to previous message
>> the jars are in
Re: Maven Core artifacts [message #568203 is a reply to message #15951] Sun, 16 November 2008 04:40 Go to previous message
Maven artifacts.
Dave.
Re: Maven Core artifacts [message #568237 is a reply to message #15933] Tue, 18 November 2008 16:29 Go to previous message
>> the jars are in
Previous Topic:packaging problem
Next Topic:Eclipse-Plugins as consumeable Maven-Artifacts?
Current Time: Tue Jul 22 15:36:41 EDT 2025
Powered by FUDForum. Page generated in 0.07700 seconds
