Home » Eclipse Projects » GEF » ContentPane and layout problems/questions
ContentPane and layout problems/questions [message #166897] Thu, 03 February 2005 15:06 Go to next message
Originally posted by: no.mail.please
Hi !
I have a problem setting correctly the layout of a figure (see code at
the end). This is just a RectangularShape with a smaller
RectangularShape inside which is set as the contentpane.
This works fine and I can add children to it but I encounter two minor
problems :
- the contentPane area doesn't resize with the main shape when I resize
this one
- children can be added to the main shape even if not dropped in the
contentPane area. So they aren't visible untill you drag them in the
contentPane area.
How can I :
- make the contentPane area resize automatically ? I tried using a
FlowLayout instead of the XYLayout, but I get a contenttPane area only
when I drop a child. If there are no children, it isn't visible.
- force children to be redirected in the contentPane area when dropped
outside it but inside the parent shape ?
TIA
Arnaud
Re: ContentPane and layout problems/questions [message #166906 is a reply to message #166897] Thu, 03 February 2005 15:13 Go to previous messageGo to next message
Here is the code, sorry.
class BeanBoxEditPart extends AbstractGraphicalEditPart
implements PropertyChangeListener {
private IFigure contentPane;
private static final int BORDER_WIDTH = 10;
* Upon activation, attach to the model element as a property change
listener.
public void activate() {
if (!isActive()) {
super.activate();
((ModelElement) getModel()).addPropertyChangeListener(this);
* Upon deactivation, detach from the model element as a property
change listener.
public void deactivate() {
if (isActive()) {
super.deactivate();
((ModelElement) getModel()).removePropertyChangeListener(this);
/* (non-Javadoc)
* @see org.eclipse.gef.editparts.AbstractEditPart#createEditPolicie s()
protected void createEditPolicies() {
// allow removal of the associated model element
//installEditPolicy(EditPolicy.COMPONENT_ROLE, new
ShapeComponentEditPolicy());
// handles constraint changes (e.g. moving and/or resizing) of model
elements
// and creation of new model elements
XYLayout layout = (XYLayout) getContentPane().getLayoutManager();
installEditPolicy(EditPolicy.LAYOUT_ROLE, new
ShapesXYLayoutEditPolicy(layout));
/*(non-Javadoc)
* @see org.eclipse.gef.editparts.AbstractGraphicalEditPart#createFi gure()
protected IFigure createFigure() {
IFigure f = new RectangleFigure();
XYLayout layout = new XYLayout();
f.setLayoutManager(layout);
f.setOpaque(true);
f.setBackgroundColor(ColorConstants.lightBlue);
contentPane = new RectangleFigure();
contentPane.setLayoutManager(new FreeformLayout());
contentPane.setOpaque(true);
contentPane.setBackgroundColor(ColorConstants.gray);
f.add(contentPane, new Rectangle(f.getClientArea().x + BORDER_WIDTH,
f.getClientArea().y + BORDER_WIDTH,f.getClientArea().width -
BORDER_WIDTH, f.getClientArea().height - BORDER_WIDTH ));
return f;
private BeanBox getCastedModel() {
return (BeanBox) getModel();
/* (non-Javadoc)
* @see org.eclipse.gef.editparts.AbstractEditPart#getModelChildren( )
protected List getModelChildren() {
return getCastedModel().getChildren(); // return a list of shapes
* (non-Javadoc)
* @see org.eclipse.gef.GraphicalEditPart#getContentPane()
public IFigure getContentPane(){
return contentPane;
/* (non-Javadoc)
* @see
java.beans.PropertyChangeListener#propertyChange(java.beans. PropertyChangeEvent)
public void propertyChange(PropertyChangeEvent evt) {
String prop = evt.getPropertyName();
if (BeanBox.SIZE_PROP.equals(prop) || BeanBox.LOCATION_PROP.equals(prop)) {
refreshVisuals();
// these properties are fired when Shapes are added into or removed from
// the ShapeDiagram instance and must cause a call of refreshChildren()
// to update the diagram's contents.
if (BeanBox.CHILD_ADDED_PROP.equals(prop)
|| BeanBox.CHILD_REMOVED_PROP.equals(prop)) {
refreshChildren();
protected void refreshVisuals() {
// notify parent container of changed position & location
// if this line is removed, the XYLayoutManager used by the parent
container
// (the Figure of the ShapesDiagramEditPart), will not know the bounds
of this figure
// and will not draw it correctly.
Rectangle bounds = new Rectangle(getCastedModel().getLocation(),
getCastedModel().getSize());
((GraphicalEditPart) getParent()).setLayoutConstraint(this,
getFigure(), bounds);
* EditPolicy for the Figure used by this edit part.
* Children of XYLayoutEditPolicy can be used in Figures with XYLayout.
private class ShapesXYLayoutEditPolicy extends XYLayoutEditPolicy {
* Create a new instance of this edit policy.
* @param layout a non-null XYLayout instance. This should be the
layout of the editpart's
* figure where this instance is installed.
* @throws IllegalArgumentException if layout is null
* @see BeanBoxEditPart#createEditPolicies()
ShapesXYLayoutEditPolicy(XYLayout layout) {
if (layout == null) {
throw new IllegalArgumentException();
setXyLayout(layout);
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy#cre ateAddCommand(org.eclipse.gef.EditPart,
java.lang.Object)
protected Command createAddCommand(EditPart child, Object constraint) {
// not used in this example
return null;
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy#cre ateChangeConstraintCommand(org.eclipse.gef.requests.ChangeBo undsRequest,
org.eclipse.gef.EditPart, java.lang.Object)
protected Command createChangeConstraintCommand(ChangeBoundsRequest request,
if (child instanceof ShapeEditPart && constraint instanceof Rectangle) {
// return a command that can move and/or resize a Shape
return new ShapeSetConstraintCommand(
(Shape) child.getModel(), request, (Rectangle) constraint);
return super.createChangeConstraintCommand(request, child, constraint);
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy#cre ateChangeConstraintCommand(org.eclipse.gef.EditPart,
java.lang.Object)
protected Command createChangeConstraintCommand(EditPart child,
return null;
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.LayoutEditPolicy#getCreateComma nd(org.eclipse.gef.requests.CreateRequest)
protected Command getCreateCommand(CreateRequest request) {
Object childClass = request.getNewObjectType();
if (childClass == Shape.class) {
// return a command that can add a Shape to a BeanBox
return new ShapeCreateCommand(BeanBoxEditPart.this.getCastedModel(),
request);
return null;
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.LayoutEditPolicy#getDeleteDepen dantCommand(org.eclipse.gef.Request)
protected Command getDeleteDependantCommand(Request request) {
return null;
Re: ContentPane and layout problems/questions [message #166914 is a reply to message #166906] Thu, 03 February 2005 15:32 Go to previous messageGo to next message
OK, another time I found the answer myself (I shouldn't work so late,
it's not good for my mind !).
I just added :
Rectangle childbounds = new Rectangle(10, 10, bounds.width - 20,
bounds.height - 50);
XYLayout layout = (XYLayout) getFigure().getLayoutManager();
layout.setConstraint(contentPane, childbounds);
in the refreshVisuals() method to get the contentPane area resize with
the main shape ("bounds" are the Rectangle value of the main shape bounds).
But I've still got the second problem that is forcing the children to be
redirected in the contentPane area when added outside it but inside the
main shape. I guess this should be a layout edit policy.
Arnaud
Re: ContentPane and layout problems/questions [message #167153 is a reply to message #166914] Sun, 06 February 2005 02:14 Go to previous message
When you get the request to add the child, your edit policy can check for
this case and change the coordinates that the command gets, if required.
"Arnaud" <no@mail.please> wrote in message
news:ctu1oa$rnq$1@www.eclipse.org...
> I just added :
bounds).
> Arnaud
Previous Topic:Layout managers
Next Topic:IAction vs. EditorActionDelegate
Current Time: Sun Jun 22 21:18:01 EDT 2025
Powered by FUDForum. Page generated in 0.09294 seconds
