perference change listner error [message #166712] |
Tue, 22 August 2006 16:55 |
When starting Eclipse 3.2 I get an error "Error notifying a perference
change listner. Check the log for details." I don't knkow what log I
am suppose to check. The OK button does not get rid of the error
message, but when I use the Windows Task Manager th close the task I get
a messsage saying JVM terminated. Exit code = 1073807364
Re: perference change listner error [message #166720 is a reply to message #166712] |
Tue, 22 August 2006 17:07 |
Originally posted by: jefmyers.us.ibm.com
What are you doing when the error happens? What additional plug-ins, if
any, have you added to your Eclipse 3.2 installation?
- Jeff
Re: perference change listner error [message #166726 is a reply to message #166720] |
Tue, 22 August 2006 17:08 |
Oh, and the log you should look at is the .log file in your workspace's
..metadata directory. It'd be helpful to post the last few entries in
your response to the newsgroup.
- Jeff
Re: perference change listner error [message #166759 is a reply to message #166726] |
Tue, 22 August 2006 18:48 |
Originally posted by: joel.g.altman.nasa.gov
I was launching Eclipse when the error occured. Thanks to your help, II
found the log. The last log entry starts out as follows:
!ENTRY org.eclipse.ui.workbench 4 2 2006-08-22 11:54:50.417
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.cdt.internal.ui.text.CTextTools.adaptToPreferenc eChange(CTextTools.java:238)
org.eclipse.cdt.internal.ui.text.CTextTools$PreferenceListen er.propertyChange(CTextTools.java:38)
org.eclipse.ui.preferences.ScopedPreferenceStore$3.run(Scope dPreferenceStore.java:372)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.preferences.ScopedPreferenceStore.firePropert yChangeEvent(ScopedPreferenceStore.java:369)
org.eclipse.ui.preferences.ScopedPreferenceStore.setToDefaul t(ScopedPreferenceStore.java:663)
Do you need to see any more?
Joel Altman
> - Jeff
FUDForum. Page generated in 0.07899 seconds
