Eclipse 3.2 installation problem on OS X Tiger [message #166510] |
Sun, 20 August 2006 07:39 |
Originally posted by: untz786.yahoo.com
Hello there,
I downloaded the Eclipse 3.2 tarball for OS X Tiger... Also installed the
JDK 1.5.0_4 and SWT_compatibility for Eclipse 3.2.
Too my surprise the only thing that was inside the tarball was a plug-ins
directory, I moved this directory over my current eclipse's plug-in
directory and launched eclipse.
The splash screen did specify that I was using Eclipse 3.2. However, right
after the splash screen, the app crashed and had me refer to a log under
Configuration.
Here's what the log stated:
===== Display starts at offset 64700 within file of length 195772. ====
===== Use File->Reload (Cmd-R) to display more. ====
scanDoctypeDecl(XMLDocumentScannerImpl.java:595)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDispatcher.dispatch(XMLDocumentScannerImpl.java:860 )
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
org.eclipse.update.core.model.DefaultSiteParser.parse(Defaul tSiteParser.java:126)
org.eclipse.update.core.model.SiteModelFactory.parseSite(Sit eModelFactory.java:78)
org.eclipse.update.internal.core.SiteURLFactory.createSite(S iteURLFactory.java:78)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:330)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:322)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:294)
org.eclipse.update.internal.core.InternalSiteManager.attempt CreateSite(InternalSiteManager.java:218)
org.eclipse.update.internal.core.InternalSiteManager.getSite (InternalSiteManager.java:159)
at org.eclipse.update.core.SiteManager.getSite(SiteManager.java :78)
org.eclipse.update.search.UpdateSearchRequest.searchOneSite( UpdateSearchRequest.java:345)
org.eclipse.update.search.UpdateSearchRequest.performSearch( UpdateSearchRequest.java:253)
at org.eclipse.update.ui.UpdateJob.runUpdates(UpdateJob.java:20 0)
at org.eclipse.update.ui.UpdateJob.run(UpdateJob.java:163)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.441
!MESSAGE Error parsing site stream.
!STACK 0
org.xml.sax.SAXParseException: White spaces are required between publicId
and systemId.
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(ErrorHandlerWrapper.java:236)
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(ErrorHandlerWrapper.java:215)
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:386)
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:316)
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(XMLScanner.java:1438)
com.sun.org.apache.xerces.internal.impl.XMLScanner.scanExter nalID(XMLScanner.java:1024)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.scanDoctypeDecl(XMLDocumentScannerImpl.java:595)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.442
!STACK 0
and systemId.
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.444
!MESSAGE Unable to access "http://update.eclipse.org/updates/3.0".
!STACK 1
org.eclipse.core.runtime.CoreException: org.xml.sax.SAXException:
FWK005 parse may not be called while parsing.
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1283)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.445
!STACK 0
org.xml.sax.SAXException: FWK005 parse may not be called while parsing.
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.447
!STACK 0
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.448
!MESSAGE Unable to access "http://update.eclipse.org/updates/3.1".
!STACK 1
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.449
!STACK 0
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.450
!STACK 0
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.451
!STACK 1
org.eclipse.core.runtime.CoreException: org.xml.sax.SAXParseException:
White spaces are required between publicId and systemId.
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.453
!STACK 0
and systemId.
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.455
!STACK 0
and systemId.
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.456
"http://download.eclipse.org/tools/uml2/updates/".
!STACK 1
org.eclipse.core.runtime.CoreException: org.xml.sax.SAXException: The
XML stream is not a valid default "site.xml" file. The root tag is not
site.
org.eclipse.update.core.model.DefaultSiteParser.handleInitia lState(DefaultSiteParser.java:365)
org.eclipse.update.core.model.DefaultSiteParser.startElement (DefaultSiteParser.java:170)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(XMLNSDocumentScannerImpl.java:330)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl$NSContentDispatcher.scanRootElementHook(XMLNSDocumentSc annerImpl.java:779)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1794)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.458
!STACK 0
org.xml.sax.SAXException: The XML stream is not a valid default "site.xml"
file. The root tag is not site.
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.460
!STACK 0
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:32:05.461
!STACK 1
site.
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.463
!STACK 0
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:32:05.465
!STACK 0
!ENTRY org.eclipse.update.core 4 42 2006-08-19 22:40:47.360
!MESSAGE Network connection problems encountered during search.
!SUBENTRY 1 org.eclipse.update.core 4 0 2006-08-19 22:40:47.361
!MESSAGE Unable to access "http://scala.epfl.ch/downloads/eclipse".
!STACK 1
site.
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(XMLDTDValidator.java:798)
com.sun.org.apache.xerces.internal.impl.XML11NSDocumentScann erImpl.scanStartElement(XML11NSDocumentScannerImpl.java:354)
com.sun.org.apache.xerces.internal.impl.XML11NSDocumentScann erImpl$NS11ContentDispatcher.scanRootElementHook(XML11NSDocu mentScannerImpl.java:855)
org.eclipse.update.internal.ui.views.FindUpdatesAction$Track edUpdateJob.run(FindUpdatesAction.java:93)
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:40:47.363
!STACK 0
!SUBENTRY 2 org.eclipse.update.core 4 0 2006-08-19 22:40:47.364
!STACK 0
Aug 19 23:04:26 Raven configd: SecKeychainFindGenericPassword err=
-25308 ( =0xffff9d24, secErrStr=User interaction is not allowed. )
(current= Phantom's Den)
!SESSION 2006-08-19 23:07:54.303
eclipse.buildId=I20050627-1435
java.version=1.5.0_02
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/untz/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch ppc -keyring
/Users/untz/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.update.configurator 2006-08-19 23:08:10.14
!MESSAGE Could not install bundle plugins/com.ibm.icu_3.4.4.1.jar No
match is available for the required execution environment:
CDC-1.0/Foundation-1.0,J2SE-1.3
!ENTRY org.eclipse.ui 2 0 2006-08-19 23:08:21.664
!MESSAGE Warnings while parsing the commands from the
'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension
points.
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-19 23:08:21.666
!MESSAGE Commands need a name: plug-in='org.rubypeople.rdt.ui',
commandId='org.rubypeople.rdt.ui.edit.text.ruby.comment'.
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-19 23:08:21.667
commandId='org.rubypeople.rdt.ui.edit.text.ruby.uncomment'.
commandId='org.rubypeople.rdt.ui.edit.text.ruby.content.assi st.proposals'.
java.lang.NoClassDefFoundError:
org/eclipse/update/operations/IInstallFeatureOperation
at org.eclipse.update.ui.UpdateJob.getUpdates(UpdateJob.java:25 6)
org.eclipse.update.internal.scheduler.UpdateJobChangeAdapter .done(UpdateJobChangeAdapter.java:35)
org.eclipse.core.internal.jobs.JobListeners$3.notify(JobList eners.java:39)
org.eclipse.core.internal.jobs.JobListeners.doNotify(JobList eners.java:96)
at org.eclipse.core.internal.jobs.JobListeners.done(JobListener s.java:158)
at org.eclipse.core.internal.jobs.JobManager.endJob(JobManager. java:477)
at org.eclipse.core.internal.jobs.WorkerPool.endJob(WorkerPool. java:100)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:92)
at org.osgi.util.tracker.ServiceTracker.<init>(ServiceTracker.java:162)
org.eclipse.update.internal.core.UpdateCore.getPackageAdmin( UpdateCore.java:315)
org.eclipse.update.internal.core.SiteStatusAnalyzer.status(S iteStatusAnalyzer.java:223)
org.eclipse.update.internal.core.SiteStatusAnalyzer.getStatu s(SiteStatusAnalyzer.java:110)
org.eclipse.update.internal.core.SiteStatusAnalyzer.getFeatu reStatus(SiteStatusAnalyzer.java:131)
org.eclipse.update.internal.core.SiteLocal.getFeatureStatus( SiteLocal.java:354)
org.eclipse.update.internal.search.UpdatesSearchCategory$Upd ateQuery.isBroken(UpdatesSearchCategory.java:181)
org.eclipse.update.internal.search.UpdatesSearchCategory$Upd ateQuery.run(UpdatesSearchCategory.java:219)
org.eclipse.update.search.UpdateSearchRequest.searchOneSite( UpdateSearchRequest.java:381)
!SESSION 2006-08-19 23:15:00.930
!ENTRY org.eclipse.update.configurator 2006-08-19 23:15:19.705
!ENTRY org.eclipse.ui 2 0 2006-08-19 23:15:31.290
points.
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-19 23:15:31.291
Re: Eclipse 3.2 installation problem on OS X Tiger [message #166550 is a reply to message #166510] |
Mon, 21 August 2006 13:38 |
Originally posted by: jefmyers.us.ibm.com
The Eclipse tarball should include much more than just the plugins
directory. Your unzip client probably has a problem reading the archive
(this is a known problem with StuffIt Expander) You should try
unpacking the archive with the BOMArchiveHelper, or from the Terminal
using the command 'tar xvzf <archive file>'
Hope this helps,
- Jeff
FUDForum. Page generated in 0.03909 seconds
