an internal error occurred during: "create remote VM for Visual Editor for Java" [message #166251] |
Thu, 17 August 2006 22:00 |
Originally posted by: gary.extremeground.com
A search of the Internet shows the above error could be related to
incompatible versions - but the versions I installed match the ones
listed in the VE FAQ - or an out of memory error, which also seems unlikely.
This is yet another clean install and I still can't VE to work. And I
can get Visual Classes only after doing a reset perspective. This time I
got the above error when I created a visual class. After clicking OK to
clear the error message, I still can't open the palette.
If I shut down and restart, the VE load stalls forever at 75%.
If I remove the project and start again, I can recreate the project but
then the VE again stalls at 75% loading. The VE never comes up.
Any ideas anyone?
Re: an internal error occurred during: "create remote VM for Visual Editor for Java" [message #166365 is a reply to message #166251] |
Fri, 18 August 2006 17:41 |
Originally posted by: jefmyers.us.ibm.com
Gary,
Take a look at the .log file in your workspace's .metadata directory.
Are there any errors there that sound suspicious?
- Jeff
> unlikely.
> Any ideas anyone?
Re: an internal error occurred during: "create remote VM for Visual Editor for Java" [message #166373 is a reply to message #166365] |
Fri, 18 August 2006 21:48 |
Jeff Myers wrote:
> Gary,
> - Jeff
Here's the full log. The first entry at 17:19:10 is something about
XLib. 4 seconds later comes the error which actually shows up. While
it's not quite Greek to me, I don't see anything that triggers an "Aha"
moment. :)
!SESSION 2006-08-17 16:54:34.263
eclipse.buildId=M20060118-1600
java.fullversion=GNU libgcj 4.1.2 20060715 (prerelease) (Debian 4.1.1-9)
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_CA
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.jem.proxy 2 0 2006-08-17 17:19:10.478
!MESSAGE
+++ Warning +++: Thu Aug 17 17:19:10 EDT 2006 Project (P2W)-VM for
P2W:err>
Xlib: unexpected async reply (sequence 0x4c)!
!ENTRY org.eclipse.core.runtime 4 2 2006-08-17 17:19:14.352
!MESSAGE An internal error occurred during: "Create Remote VM for Visual
Editor for Java".
!STACK 0
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.fillI nLaunchInfo(ProxyLaunchSupport.java:572)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:396)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:304)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:236)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:184)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.jem.proxy 2 0 2006-08-17 17:20:09.480
!MESSAGE
!STACK 0
java.net.SocketTimeoutException: Read timed out
at java.io.BufferedInputStream.refill(libgcj.so.7)
at java.io.BufferedInputStream.read(libgcj.so.7)
at java.io.DataInputStream.readByte(libgcj.so.7)
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1243)
org.eclipse.jem.internal.proxy.common.remote.Commands.sendIn vokeMethodCommand(Commands.java:1403)
org.eclipse.jem.internal.proxy.remote.REMConnection.invokeMe thod(REMConnection.java:209)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:219)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:190)
org.eclipse.jem.internal.proxy.remote.REMConstructorProxy.ne wInstance(REMConstructorProxy.java:61)
org.eclipse.jem.internal.proxy.swt.JavaStandardSWTBeanConsta nts.getEnvironmentProxy(JavaStandardSWTBeanConstants.java:13 3)
org.eclipse.jem.internal.proxy.swt.JavaStandardSWTBeanConsta nts.getDisplayProxy(JavaStandardSWTBeanConstants.java:143)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.onUIThr ead(UIThreadOnlyProxyAdapter.java:119)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.instant iateAndInitialize(UIThreadOnlyProxyAdapter.java:125)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:330)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:374)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:279)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1993)
!ENTRY org.eclipse.jem.proxy 2 0 2006-08-17 17:20:09.622
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
at java.lang.reflect.Method.invoke(libgcj.so.7)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:317)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:223)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:179)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:98)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:231)
!ENTRY org.eclipse.jem.proxy 2 0 2006-08-17 17:21:10.60
!MESSAGE
!STACK 0
org.eclipse.ve.internal.swt.BeanSWTUtilities.getOffScreenLoc ation(BeanSWTUtilities.java:749)
org.eclipse.ve.internal.swt.FreeFormComponentsHost$FreeFormC omponentProxy.create(FreeFormComponentsHost.java:48)
org.eclipse.ve.internal.swt.FreeFormComponentsHost$FreeFormC omponentProxy. <init>(FreeFormComponentsHost.java:45)
org.eclipse.ve.internal.swt.FreeFormComponentsHost.add(FreeF ormComponentsHost.java:149)
org.eclipse.ve.internal.swt.ControlProxyAdapter.primInstanti ateThisPart(ControlProxyAdapter.java:193)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:1239)
org.eclipse.ve.internal.swt.ControlProxyAdapter.primInstanti ateBeanProxy(ControlProxyAdapter.java:137)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teAndInitialize(BeanProxyAdapter.java:388)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.primIns tantiateAndInitialize(UIThreadOnlyProxyAdapter.java:164)
org.eclipse.ve.internal.swt.UIThreadOnlyProxyAdapter.instant iateAndInitialize(UIThreadOnlyProxyAdapter.java:126)
!ENTRY org.eclipse.ui 4 4 2006-08-17 17:21:11.772
!MESSAGE Unhandled event loop exception
Re: an internal error occurred during: "create remote VM for Visual Editor for Java" [message #166471 is a reply to message #166409] |
Sat, 19 August 2006 16:13 |
Jeff Myers wrote:
> Gary,
> Gah! You're using GCJ as your Java runtime. This isn't supported as it
> causes tons of weird errors like the ones you're seeing. You'll need to
> use a JRE from Sun or IBM to run the VE.
> - Jeff
That removes me from the Debian package system as gcj is a dependency of
Eclipse. Installing Eclipse install gcj and removing gcj removes Eclipse.
So I removed gcj and Eclipse and installed the latest Sun runtime, since
getting the IBM one seemed to involve creating an account, etc.. Then I
downloaded 3.2 and installed it. This is where things start to go wrong.
Firstly, have you ever tried to find a "how to install Eclipse" document
on the Eclipse web site? Actually, finding anything on it is nearly
impossible, but that's another issue. I remembered reading somewhere
that you just unpack the archive and run eclipse, so I tried that.
Fortunately, I also found a mention of a -vm flag in this group, so I
eventually got Eclipse to start. However, I can't get Eclipse to install
anything in my regular account. I can live with that. I don't like
installing executable code as a regular user anyway.
However, I can't get Eclipse to run as root to install the VE either. I
get:
JVM terminated. Exit code=1
/usr/local/lib/jre1.5.0_08/bin/java
-jar startup.jar
-os linux
-ws gtk
-arch x86_64
-launcher /usr/bin/eclipse
-name Eclipse
-showsplash 600
-exitdata 78cc0045
-vm /usr/local/lib/jre1.5.0_08/bin/java
-vmargs
-jar startup.jar
Sorry to be such a nuisance, but how do I get around that?
Re: an internal error occurred during: "create remote VM for Visual Editor for Java" [message #166699 is a reply to message #166471] |
Tue, 22 August 2006 16:02 |
Originally posted by: jkangash.hiit.fi
Gary Dale <gary@extremeground.com> writes:
> Jeff Myers wrote:
>> Gary,
>> it causes tons of weird errors like the ones you're seeing. You'll
>> need to use a JRE from Sun or IBM to run the VE.
> of Eclipse. Installing Eclipse install gcj and removing gcj removes
> Eclipse.
You don't need to do that, it's possible to run the Debian-packaged
Eclipse with other runtimes as well. You'll still need to have gcj
installed of course, but it won't interfere.
One option is to edit the file /etc/eclipse/java_home so that the
directory of your preferred runtime comes first (or so I understand,
that's not what I did). The other one is to add to
~/.eclipse/eclipserc the line
JAVA_HOME=<path to Java>
The latter is what I'm using and it's working well.
Jaakko Kangasharju, Helsinki Institute for Information Technology
Why doesn't the Beast use Unix?
Because it cannot run any programs.
FUDForum. Page generated in 0.08082 seconds
