ClassNotFoundException... [message #164752] |
Wed, 09 August 2006 10:07 |
Originally posted by: frederic.cuillandre.airweb.fr
hello,
i'm fed up!! i'm using eclipse and eclipseme under windows.
i have to import a zip in the build path to have access to the classes
contains in the zip.
when i code, the imports are OK: eclipse import the package contains in
the zip files but, when i run the app ( a MIDlet), i have a
ClassNotFoundException !!!
is anybody has a solution ??
regards
fred
Re: ClassNotFoundException... [message #165206 is a reply to message #164752] |
Fri, 11 August 2006 15:54 |
Originally posted by: eclipse4.rizzoweb.com
frederic wrote:
> hello,
> contains in the zip. when i code, the imports are OK: eclipse import the
> package contains in the zip files but, when i run the app ( a MIDlet), i
> have a ClassNotFoundException !!!
How are you running the application? Remember that the compile classpath
(called the "Build Path" in Eclipse) is separate from the runtime classpath.
If you are using a Launch Configuration to run your app, you need to
edit it to make sure the ZIP file is on its classpath.
The Eclipse Help can provide more details on these concepts and terms.
Hope this helps,
Eric
FUDForum. Page generated in 0.07693 seconds
